Results 1 to 7 of 7
Thread: Clatter sound, in front end of 2000 K1200 LT maybe it isn't the shock?
    To describe the sound in question, think heat shield loose or clunky tranny shift or tinny sound as opposed to solid structural bam that you can feel in the entire bike,
    This sound is a long standing problem, which I thought was a shock bottoming out, but as I get ready to approach the solution, I have begun to doubt that is the source of the tinny clattery sound.
    1. It happens without a deep shock related bounce as in when you hit tar snakes or cracks in the pavement at modest speed where there is no bottoming of the shock.
    2. Generally it doesn't happen when I am going very slow and the shock is being depressed.
    Its a rattle and it goes away unless you are hitting tarsnakes. Could it be the steering dampener? The brake calipher attachment like happens on the rear? It feels high up on the forks or shock..
    I can't really duplicate it off the bike or see what it is on the bike.
    Diagnosis tricks?
    Paul
    Feb 2010
    Cape Cod, MA
    Try tapping on the wheel with a rubber mallet. This used to work for me in a body shop I worked at. Good luck.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
    On a bike that hasn't been maintained, it could be dozens of things: brake pads, rotor bobbins, head bearings, front suspension ball joints, wheel bearings, shock bushings, loose axle, body panels, grills, windscreen, exhaust. . Hard to tell.
    May 2008
    Western Massachusetts
    I vote rotor bobbins. They're famous for making noise.
    Grab the rotors (cold!) and wiggle them. Sound familiar?
    Registered User wvandennoort's Avatar
    Branchville NJ
    Check front fender it may be cracked or loose.
    Bill Van den Noort
    2000 K1200LT
    2017 R1200RT
    MOA# 96083
    Part but not all the problem was a loose fender mount
    Checked and loose fender bolts stopped the low speed bump rattle, but not the higher speed. Can a blown fork make a similar sound. Otherwise I am thinking the stabilizer so I am going to try some urethane bushings as a cheap test on the mounting plate
    p
    May 2008
    Quote Originally Posted by mslacool View Post
    p
    Assuming what you blew was the fork seal, I wouldn't count on it. The seal just holds the oil in and the dirt out; the actual guiding is done by bushings. But if your seal has been gone for a while, you may have lost the lube oil that is supposed to be in the fork, so do pursue that and fix it.
    If I suspected the steering damper of being a problem source, I'd be tempted to take it off and take a GENTLE test ride to see if the noise went away.
  1. Front shock experiment aftermarket 2000 K1200 LT
    By mslacool in forum Flying Brick K-bikes
    Last Post: 02-15-2019, 02:48 AM
  2. How to buy a used LT shock and fork 2000 K1200 LT
    Last Post: 02-01-2019, 05:10 PM
  3. 2000 k1200 lt abs issues
    By slatefish in forum Flying Brick K-bikes
    Last Post: 10-22-2017, 12:01 AM
  4. 2000 k1200 rs
    By cayuse60 in forum Flying Brick K-bikes
    Last Post: 12-01-2009, 02:13 AM
