For those that don’t like removing the rubber timing hole cover, there are arrows on the cam chain sprockets. When the arrows are horizontal, then you are at TDC. Check the valves on each side to see which side has play. That is the side you adjust. Rotate the motor to the next arrow and then the other side should have play. Adjust that side. Yes, it is much easier to rotate the motor with the plugs out.
I always just remove the front cover and turn the crankshaft with a socket and wrench this way. It takes less than a minute to remove the cover. Why folks think turning the rear wheel in 4th or 5this easier escapes me.
I have an Ohlins shock on the front of my RT, and it's pretty darn hard to wiggle the front cover out of there.
One might also punch a hole in the cover, per info from the Internet BMW Riders site - begin quote:
I asked Duncan, of Duncan's Beemers (located in Maynard, Massachusetts), to modify my Oilhead's pulley cover so that a simple plug could be inserted directly over the spot where the 16mm pulley nut (which is used to turn the engine over to find TDC) is located.
Duncan took a new pulley cover (sure, I could have used the one on my bike, but I wasn't sure this was gonna work). He found that the 16mm nut we needed to get to was directly under the BMW embossed logo on the bottom of the black plastic cover. He speculates, and I concur, that someone at BMW once had in mind doing exactly what we did. Duncan removed the logo using a 23mm hole cutter, then cleaned up the remaining excess plastic by hand. He then took a round rubber plug; a /5 fork leg bottom (part #31422000381 – the diameter of that part of the plug which holds it in place is .926" ). The plug fits perfectly in the hole Duncan made. Now, when it comes time to do my valves, I'll only have to pop out this small rubber plug, stick my 16mm socket inside, and go to work.
My R1100RT also has Ohlins shocks, and with the front cover cut horizontally in half, it is not difficult to remove that cover. Having said that, I would still prefer to have what Duncan did to your front cover.I have an Ohlins shock on the front of my RT, and it's pretty darn hard to wiggle the front cover out of there.[/COLOR]
Wait a minute Paul, while I clean up the coffee that spilled while I was laughing. You are talking about your RS aren't you? Now, remove that front cover on the RT while you remove the side fairings, the bottom piece, and the shark fin in order to twist the front cover and drop it down and out. On the RT, turning the rear wheel in gear is a piece of cake.
... Just exactly how to watch the flywheel timing hole while turning the rear wheel was way above my pay grade....
Bike on centerstand. You - seated on stool on left side of bike. Rubber timing plug removed, bike in 5th gear. Small flashlight held in mouth. Use right foot to nudge rear wheel whilst watching flywheel turn. When TDC timing mark appears, stop turning rear wheel. What could be easier ?
The other rightIsn't the rubber plug on the right side?
