So I have decided I am not buying a used front shock and I am not spending 800 for shocks on the LT, but I have researched what a shock does and assuming my shock is totally crap, anything has to be better than nothing. So, I figure I can look for a similar length shock and spring, made for similar weight ( 400 to 500 per wheel) and put it on the LT. Other than diameter, not much else can go wrong right? If it works it works. If its better its better. If not, it was crap to begin with.
If it works, then I can so start saving all the other LTs out there.
What do you think? What length etc do you suggest. We are starting with the front end first.
If it works, I would like to try maybe raising the bike a bit. How about air shocks?
Anybody want to weigh in on my chances?
