Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 51
Thread: 2003 K1200GT - any tips on fuel filter change?
    Aug 2018
    Bolingbrook, IL
    Another question before I button this up. The tank's front bolts that you just loosen were beyond stiff. A lot of leverage needed to loosen them and once moving groaned like an old rusty bolt.
    What to do? WD40 on it, motor oil, Aluminum anti seize are on my list. The other bolts on the back side were smooth and little problem. Thanks for comments.
    2003 K1200GT
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by jrmull View Post
    I never had to loosen them. I would lift the back of the tank and slide the tank off of the front mounts.
    Is this the mount you're talking about.
    Lee
    2016 R1200RS
    MOA # 30878
    SW Iowa
    Quick release was not much fun. .
    Did you replace the quick disconnects? If not, and you need new Viton orings PM me and I'll mail you a few.
    If you replaced the QDs, save one of the old ones.
    It makes for an easy fast way to drain the tank.
    Lee
    2016 R1200RS
    MOA # 30878
    SW Iowa
    Forgot to mention the drain hose clamps. The type of clamp for the drain hoses is not a big deal because they are not under pressure.
    Lee
    2016 R1200RS
    MOA # 30878
    Aug 2018
    Bolingbrook, IL
    Yes, those are the bolts on the front of the tank which are extremely hard to loosen. I have them loose now but not smoothly turning. They are binding. On the other notes of draining the gas, that was a mess. I have it empty now for work.
    Any suggestions on the dead fly in the air intake?
    I did pick up some one-time small clamps at the auto store. Ready to button this up.
    thanks
    2003 K1200GT
    SW Iowa
    I don't know if it's a problem.
    Sometimes it's better to pretend it never happened
    Between my K1200RS and my wife's K1200RS I changed quite a few air filters, and I'm guessing one or two bugs dropped down into the airbox when changing those filters.
    Lee
    2016 R1200RS
    MOA # 30878
    Nibley, UT USA
    Fly, what fly??
    If you haven’t put the tank back in place, it’s a small matter to pop the filter cover, pull the filter, and stick a vacuum cleaner nozzle in there. I normally do that as part of my filter replacement routine anyway. And if you don’t get him out I wouldn’t be too worried about it; I don’t think flies are particularly abrasive.
    Best,
    DG
    DGerber
    Aug 2018
    Bolingbrook, IL
    Thank you for the dead fly comments. Midwest got socked with winter storm so I haven't finished closing up the tank. I have a little vacuum to give it an attempt.
    I did find smaller 3/8 clamps at Menards that are stainless steel. When reduced to size, it looks pretty bad visually. See picture. I won't see it in the tank but on the outside connections, it looks bad. The excess tail gets long too. I got some crimp clamps the right size at the auto store and will use them. Keep extras on hand for another trip under the tank.
    I can see why the dealer is using crimping types. More compact, more professional looking.
    2003 K1200GT
    Nibley, UT USA
    You don’t want that worm-drive type of clamp—it will damage the hose by the time it’s clamped tight enough to withstand fuel pressure. You want the smooth band-style clamps—either screw-type or crimp-on (Oetiker) clamps. If you’re not having any luck sourcing them at your dealer you could try a NAPA store, Amazon, or McMaster-Carr.
    https://www.amazon.com/s?k=Fuel+inje...f=nb_sb_noss_2
    https://www.mcmaster.com/hose-clamps
    Best,
    DG
    DGerber
    SW Iowa
    Quote Originally Posted by GTRider View Post
    DG
    I think he's talking about the small vent or drain hoses??
    In his picture he has the correct type of clamp on the fuel lines.
    Lee
    2016 R1200RS
    MOA # 30878
  11. #26
    Aug 2018
    Bolingbrook, IL
    It lives. Filled a half gallon and pump activated. Started up fine.
    I ended up using the screw band on the venting tubes. The small tube are non pressured and I didn't mash them tight. The main filter tubes were replaced and I used Max screw type that have a solid band. I was happy with that and future removal easy. I was more comfortable using screwdriver pressure to tighten that a crimping tool. For the vent tubes, it was tight using the Menard threaded band. It was stainless steel and those venting tubes need to be pull to work on the filter. That was my approach. I appreciate the warnings DG is advising. Only part not replaced was the screen for $70. I will send that one back to the store.
    On the vent tube outside the tank, they also have to be removed frequently to pull the tank. I couldn't get my crimping tool in there. The screw type worked for minimal pressure on the tubes. One worry is the band extends over the top of the fuel line. I need to keep it from rubbing. I will figure out something or go back to crimping. I have a box of crimping clamps but thanks for the offer on sourcing parts.
    I dug out from another shed the shop vac. Improvised using my oil fuel to get deep into the air box. No dead fly found. Maybe my vacuum process turned it to dust. Well worth the try. I was quite proud of my invention.
    Somewhere, I misplaced that tank washer and rubber grommet that Lee was talking about. %@@$%% That wasted a couple hours. I found the washer but missing the thin rubber grommet. I kept putting on the tank, losing the big rubber insert. Tank back off, search, find, repeat. Grommet pops out, tank back off, search, find, repeat. New swear words invented. I see someone prior used rubber cement to hold the center grommet in place. I tried tape. Eventually it worked less a thin rubber grommet on the outside bolt.
    Oh and I scratch the tank top.
    Still have some clean up to do. Replace the quick release Orings, Test ride to look for leaks or panel warning lights. Order a couple tank grommets.
    Thanks for all the assistance. John
    2003 K1200GT
  12. #27
    SW Iowa
    You can get by without a clamp on those two vent lines outside the tank.
    The hose has a snug fit on the metal tube and their's plenty of overlap.
    Lee
    2016 R1200RS
    MOA # 30878
  13. #28
    Aug 2018
    Bolingbrook, IL
    Ugh. Bike won't start. 2003 K1200GT 26k miles
    I finished changing the fuel and air filter this week. Replaced the quick disconnect ORings. I had it running several times this week checking leaks, etc and it was running with out panels naked.
    I put the panels back on and it started and idled fine for about 2-3 mins. Then sputtered and shut off. I was going to let it warm up for awhile but it didn't get that far. I figured low/out of fuel since I had just a small amount in and the yellow low fuel light was on anyway.
    I filled the tank to 1/4 on the gas gauge. About 2 gallons premium. It won't start. I smell some fuel out the exhaust. Low fuel light is off now with all the gas in the tank.
    Waited another couple hours. Still won't start. I hear the fuel pressurize and no warning lights. Just cranks. I guess I will try the battery disconnect tomorrow is if that resets the computer.
    Worst case, find that diagnostic tool.
    It is on the center stand. Side stand it up, Kill switch ready, Neutral gear. Clutch in on start. Good battery power and crank speed. I am thinking running out of fuel, wacked the computer codes. Has it in some shutoff mode. Beat me.
    2003 K1200GT
  14. #29
    Nibley, UT USA
    When you turn on the switch do you hear the fuel pump energize briefly? And of you do, please repeat the test only with the fuel cap open and your ear down there listening for fuel squirting/splashing inside the tank. Please report back...
    Best,
    DG
    DGerber
  15. #30
    SW Iowa
    Sounds like the two electrical connectors are in place.
    Lee
    2016 R1200RS
    MOA # 30878
  1. 2003 K1200GT - Final Drive oil change
    By jrmull in forum Flying Brick K-bikes
    Last Post: 12-11-2018, 06:01 AM
  2. Looking for an ignition-on Hot wire, any tips- 2003 k1200gt
    Last Post: 08-28-2018, 12:02 AM
  3. Oil and Filter Change - 2003 R1200C - Please help
    By primechuck70 in forum Oilheads
    Last Post: 04-24-2013, 01:45 PM
  4. 03 k1200GT fuel filter
    By jeffd in forum Flying Brick K-bikes
    Last Post: 02-20-2012, 05:39 PM
  5. Oil Change Question K1200GT 2003
    By VTRider500 in forum Flying Brick K-bikes
    Last Post: 08-18-2009, 05:20 AM
