Results 1 to 8 of 8
Thread: Brick Oil Use?
    May 2008
    Western Massachusetts
    Brick Oil Use?
    I just noticed this subject referenced on another post. Don't worry it's not about what oil is best for your bike. I already know the answer to that
    I'm curious if you guys see oil consumption by your Bricks.
    FWIW, I used to see some oil loss between changes in the old K100s I had. Once I moved to K11s it was mostly gone. K12s I've had never used any.
    Yours?
    Apr 2006
    Nibley, UT USA
    About a cup every 1500 miles or so, but that’s on a K12 with 95k miles and pulling a sidecar rig with two people and luggage.
    To whom at BMW do I complain about this consumption?
    Best,
    DG
    DGerber
    1983 R80ST — 1984 R80 G/S PD — 1993 R100GS — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT
    Apr 2013
    Southern California USA
    I bought a very low mile '93 k75, it had 3,100 miles on it when i got it. I'm using 15w 50 mobil 1 in the engine. I started with oil level about 1/8 inch from the top circle (red circle) and now at 4,225 miles, I'm about 1/8 inch above the center dot. So not too alarming, but a little consumption, perhaps it's still braking in or finding it's own level, like my airheads do. I've never had a brick before but always was curious about them and this one showed up, pristine and local. Had to have it. Chunk.
    Quote Originally Posted by chunk View Post
    What you describe is only about 2 to 3 ounces of oil in 4,225 miles. I don't consider that consumption worth thinking about because you will not need to add any oil between changes.
    Apr 2013
    No, i think you may have miss read my post. I started with 3,100 miles when i got it, now at 4,225 miles, = 1125 miles ridden total. Chunk.
    RK Ryder
    London, Ontario
    My '87 K100RT burns very little oil, like nil. The exemption is if riding the mountains for a few days, with constant change in speeds and gear changes, it will burn enough to be noticeable, but not enough to be worrisome.
    The odometer is now sitting at 267, 000 km, using Castrol 20-50 oil.
    Paul
    Niagara Riders & Knights of the Roundel #333
    Contact me and become a Volunteer in Lebanon! rallyvolunteers@bmwmoa.org
    OK. Two ounces per thousand is ten ounces per 5000 miles which is the change interval suggested back in '91. So say 12 ounces in a 6000 mile change interval as later specified for K75s. Well within reason and with an almost 4 quart (128 ounces) those 12 ounces are insignificant. Just ride it. If the level reaches the circle at the bottom of the sight glass top it off with 8 or so ounces of oil. That would get you to your next oil change.
    Apr 2013
    Yep, that's my thoughts too. I still think as the miles add up, the rings may seat in a little more, after all the motors still pretty new. Cheers, Chunk.
  1. Going outside of the brick
    By ghostridery2k in forum Flying Brick K-bikes
    Last Post: 06-21-2011, 04:05 AM
  2. K75 vs K1200 (brick)
    By lostandwandering in forum Flying Brick K-bikes
    Last Post: 01-31-2010, 11:14 PM
  3. New (used) Brick
    By RAGMAN in forum Flying Brick K-bikes
    Last Post: 03-31-2008, 11:14 PM
  4. brick or bumblebee
    By soccerchainsaw in forum Flying Brick K-bikes
    Last Post: 03-25-2008, 06:24 PM
  5. Brick or Air???
    By JOECUBANA in forum Flying Brick K-bikes
    Last Post: 10-08-2004, 06:16 PM
