Just replaced all brakes lines with Galfer braided ss lines. I have bled the lines numerous times so I know the procedure. The front right brake caliper has the fill adapter and grub screw which I plan on replacing with a speed bleeder. When replacing the fill adapter do I just remove the grub screw and replace it with the speed bleeder or remove both screw and fill adapter, then thread the speed bleeder directly into the caliper. I understand a little heat and gentle love to soften the Loctite is needed. Thanks for the help, Gregory 99 RT 60k miles
