Results 1 to 11 of 11
Thread: 2006 RT Where is the main fuse panel?
    Registered User tasslehawf's Avatar
    Feb 2016
    Austin, TX
    I assumed it was under the seat but no luck. I don't seem to have the manual.
    2007 F800S
    2006 R1200RT
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    You will never find it. The R1200RT has no fuse panel.
    It has a CANBus system which is like a breaker panel that resets itself when you turn the ignition Off/On
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    It is safely ensconced at and controlled by BMW conglomerate HQs in Munich.
    Kevin Huddy
    Tm Pterodactyl's MT Outpost
    2017 R1200GSA & 2013 FJR
    Feb 2016
    Austin, TX
    LOL. Ok. Bike won't turn on so its not a fuse...
    2007 F800S
    2006 R1200RT
    Jun 2009
    Rochester, MN
    Quote Originally Posted by tasslehawf View Post
    That's an easy fix.... found here: http://www.bmw-motorrad.com/com/en/services/manuals/manuals_main.html
    Current: 2007 BMW R1200RT
    Jul 2007
    Battery?
    Kevin Huddy
    Feb 2016
    Austin, TX
    Quote Originally Posted by akbeemer View Post
    Battery?
    Battery is 100% fully charged and brand new as of a few weeks ago.
    Replaced the battery after the holidays when I found it had somehow been discharged to 4.8v on its own (sat about a week over the holidays).
    Got the new battery in there one morning and tried to ride to work, but the bikes power shut off completely during the ride and would not come back on.
    I found that if I removed and replaced the battery lead, it bike will come back on.
    These are the codes I found the last time I ran the diagnostic tool:
    Fault Codes : 4
    41704 : KL30 (Battery positive) under voltage
    Currently present : NO
    Symptom : Signal or value under threshold
    Engine warning light (MIL) : NO
    Frequency count : 1
    Logistic(Healing) count : 39
    Fault Code History : Unknown
    41721 : Park light short-circuit
    Symptom : Signal or value over threshold
    Engine warning light (MIL) : YES
    Frequency count : 10
    Logistic(Healing) count : 40
    41722 : Park light open-circuit
    Symptom : No signal or value
    Frequency count : 36
    41758 : Battery Positive (KL30) over-voltage
    Frequency count : 6
    2007 F800S
    2006 R1200RT
    Feb 2016
    Austin, TX
    Does the bike have a regulator-rectifier? And if so, where is it?
    I assume I will have to take plastics off to get to it.
    2007 F800S
    2006 R1200RT
    It is internal to the alternator, as it should be with modern machinery.
    OK...stupid question....
    Have you checked the bike to make sure it has a good ground connection?
    Tasslwhawf...check your PMs...sent you a message.
  1. Is there a fuse panel on my 2010 RT
    By roadstar in forum Hexheads/Camheads
    Last Post: 01-26-2013, 11:46 PM
  2. Centech Fuse Panel DIY
    By Semper_Fi in forum Wedge K-bikes
    Last Post: 02-17-2010, 02:36 AM
  3. where did you mount your Fuse Panel
    By rmeisen in forum Hexheads/Camheads
    Last Post: 05-26-2008, 02:17 AM
  4. Aux fuse panel for F650GS
    By Yellowjacket in forum Thumpers - F & G bikes
    Last Post: 05-15-2008, 06:20 AM
  5. Aux fuse panel for F650GS
    By Yellowjacket in forum Forum Software Specific Help. NOT for bike related questions.
    Last Post: 01-21-2008, 03:57 AM
