2006 RT Where is the main fuse panel?
You will never find it. The R1200RT has no fuse panel.
It has a CANBus system which is like a breaker panel that resets itself when you turn the ignition Off/On
Battery is 100% fully charged and brand new as of a few weeks ago.
Replaced the battery after the holidays when I found it had somehow been discharged to 4.8v on its own (sat about a week over the holidays).
Got the new battery in there one morning and tried to ride to work, but the bikes power shut off completely during the ride and would not come back on.
I found that if I removed and replaced the battery lead, it bike will come back on.
These are the codes I found the last time I ran the diagnostic tool:
Fault Codes : 4
41704 : KL30 (Battery positive) under voltage
Currently present : NO
Symptom : Signal or value under threshold
Engine warning light (MIL) : NO
Frequency count : 1
Logistic(Healing) count : 39
Fault Code History : Unknown
41721 : Park light short-circuit
Symptom : Signal or value over threshold
Engine warning light (MIL) : YES
Frequency count : 10
Logistic(Healing) count : 40
41722 : Park light open-circuit
Symptom : No signal or value
Frequency count : 36
41758 : Battery Positive (KL30) over-voltage
Frequency count : 6
Does the bike have a regulator-rectifier? And if so, where is it?
I assume I will have to take plastics off to get to it.
OK...stupid question....
Have you checked the bike to make sure it has a good ground connection?
