Results 1 to 15 of 15
Thread: Aux light mounting options
    I don't even have the bike yet, pick it up April 1, but I already have a set of Denali D2's one the way. I had this on my last 2 bikes and wanted them on the 03 RT. But ublike the other bikes I am not finding much in way of mounting options. Denali selle ths universal offset fender ones but I am sure that I am missing what other optionsa are out there.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Registered User jnrugg's Avatar
    Sep 2007
    Danielson, Ct.
    I don't have any but I have seen brake caliper mounts.
    Registered User beemermyke's Avatar
    Richmond Hill, Georgia
    Motolights (I had some on my 1150RS) had the caliper mount option. They supplied the mount and a single longer brake caliper mount bolt. Maybe they have a similar mount?
    Motorcycling is my passion because golf is far too dangerous!
    2016 R1200GSW
    RK Ryder
    London, Ontario
    The position of my PIAAs makes a large triangle.
    Paul F. Ruffell
    Niagara Riders & Knights of the Roundel #333
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by PAS View Post
    Will they fit here?
    Nicely done, PAS!
    They call me Gort scootrp125x's Avatar
    Sep 2004
    Argyle Texas
    I would like to mount my Denali lights in the same place that you have yours. I assume you drilled holes from the underside of that area. Is that how you installed them and was it difficult to drill through the plastic?
    04 R1150RT
    Tutum amicus r184's Avatar
    Jan 2008
    So Cal
    Quote Originally Posted by scootrp125x View Post
    Also have a very similar '04 with lights in same place. The light bracket mounted to some pre-existing holes/bolts. Just unbolted, mounted the brackets/lights and tightened the bolts. Did the same with a previous '02 K1200RS, same mounting points.
    No Matter Where I went, There I was...
    RK Ryder
    London, Ontario
    Mine were originally mounted under the oil cooler but the triangle was too small (for my liking) and on occasion, they would hit the front fender and left marks on the fender.
    Paul F. Ruffell
    Sep 2004
    Argyle Texas
    Quote Originally Posted by r184 View Post
    Thanks. I will look for those bolt holes to use. I will also have to get some brackets or fabricate them.
    04 R1150RT
    Sep 2004
    Argyle Texas
    Quote Originally Posted by Paul_F View Post
    Thanks for the info. These lights are fairly small. I will make sure they are well above the fender.
    04 R1150RT
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    Here are some inexpensive LED lights I got off ebay, had to make brackets to mount on my RS model. Since I didn't have heated grips, bought some OEM switches which I used to turn them off an on/off.
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Honda XL600R
    Sep 2004
    Argyle Texas
    Quote Originally Posted by jagarra View Post
    Thanks for the information.
    04 R1150RT
    skibum69 skibum69's Avatar
    Dec 2016
    New Melbourne, NL
    This is probably not an option for you
    http://beerthief.ca
    ITSteve: ride in peace my friend
    save $5 on a new SmugMug account, use this coupon7frrnSRiTt9Fk
    Sep 2004
    Argyle Texas
    Quote Originally Posted by skibum69 View Post
    Unfortunately I don't have space like that on my bike.
    I made a few calls to try to find mounting brackets but had no luck. Yesterday I stopped at Lowes and bought what I believe will work for under $20. I will be able to mount my light in the same area as PAS's lights.
    04 R1150RT
  1. GPS mounting options for the K1200RS
    By bubbadozer1 in forum Flying Brick K-bikes
    Last Post: 10-27-2017, 09:00 PM
  2. RAM mounting options for R100 GS - Looking For
    By GlobalRider in forum Airheads
    Last Post: 05-13-2014, 01:15 AM
  3. Looking for Zumo mounting options on a GS
    By roburnmc in forum Hexheads/Camheads
    Last Post: 02-27-2008, 03:21 PM
  4. ZUMO 550 Mounting Options
    By pschramm in forum Gear
    Last Post: 05-15-2007, 07:28 PM
  5. XM vs. Sirius and mounting options
    By DZIMBRIC in forum Gear
    Last Post: 05-24-2005, 08:10 PM
