Results 1 to 4 of 4
Thread: r12gs&turn signal bulbs
    Oct 2003
    AVELLA PA
    Lightbulb r12gs&turn signal bulbs
    Does anyone know where to purchase these bulbs that are chrome so they can't be seen by using clear lenses and what are the size of these bulbs in according to american auto parts stores to ask for??
    Boise, ID
    Quote Originally Posted by boxxer
    I've used the Sylvania SilverStar signal bulbs: http://www.sylvania.com/ConsumerProd...verStarSignal/ They look a little blue in the daylight, but are full on amber when powered up day or night. You can look here for the fitment: http://tinyurl.com/8q8to but I believe the 1156 will work.
    Some of the BMW turn signal bases which come with clear lenses have a weird bulb base where the pins are offset as seen when looking at the base of the blub. The pins are not directly opposed from each other (180 degrees apart). My local dealer just uses a standard 1156 bulb and removes one of the pins. The single remaining one seems to keep the bulb in the socket ok.
    Greg Feeler
    Ambassador & amateur K-Bike collector, it seems
    Urbana, IL
    Quote Originally Posted by GregFeeler
    The clear lens reflectors take the non-180 opposed pins and use the amber bulb that BMW supplies with those non-180 pins. The amber lens reflectors take the standard clear bulb with the 180 degree opposed pins.
    However if you look at the reflectors and the lenses, there is a mating notch on the side of the reflector which mates with the proper lens. If you notch the other side of the wrong reflector (or lens), then you can mix them. The point being that you don't have to replace the reflector which takes the clear bulb and then you can use the US made amber bulbs with the 180 degree opposed pins...and save buying the BMW amber bulb reflector.
    My other bike is a BMW.
    Boise, ID
    Quote Originally Posted by cjack
    That's exactly what I did on my K1200RS.
    Greg Feeler
