I didn't expect a choke line to pull on a fuel injected machine, but my 2003 K1200GT won't start today. Last run 3-4 days ago.
Temp is 12 degrees in garage out of the wind. Battery fresh. 12.1vt meter reading. It turned over, caught a spark once. Continued churring and gave up. When once cough came though, my starter had an evil scratching complaint but not broken.
Went back an hour late. Checked the usual, neutral gear, clutch in, kick stand back and on center stand, kill switch normal on. Fiddled with the throttle. Checked for mouse nest in the muffler. Tried the starter with throttle open a smig. Repeat of the single chug. Time to think.
My vin show build date of 11/2002. Some blogs talk about ECU unit upgrades. What is the best stable ECU recommended for low idle? I haven't had any engine power or idle problems.
Maybe I didn't let the pressure build enough. I just turned the key and went to work on the starter button. I will try that in the morning letting the pressure build up.
Let me know of any tricks you have found helpful on a cold morning.
