Results 1 to 6 of 6
Thread: 2005 K1200S Clutch fluid
    Jan 2019
    Ingleside , Illinois
    I was planning on flushing out the clutch fluid . What is the " Mineral Oil " that they speak of ? Can I just use DOT 4 brake fluid ? What happens if I do ?
    Liaison 20774's Avatar
    Past thread that discusses what "mineral oil" is:
    https://forums.bmwmoa.org/showthread...ir-Cap-Removal
    Left Coast Rider
    Quote Originally Posted by bige1340 View Post
    1.No.
    2.Bad things
    Mineral oil doesn't absorb moisture which is a plus. Its used because it doesn't have to deal with the heat generated in a braking system. Its also favoured by more than one European bike manufacturer. I don't believe the seals in our clutch hydraulic system are compatible with DOT 4.
    Mineral oil is available from your favourite BMW or KTM store.
    CENTEX USA
    ditto on the NO DOT 4.
    BMW has two different part numbers for the mineral oil as well. There is a red and a blue. Thinking out loud, the blue was in the parts fiche on the Wedgies. I have both and if any work is done on the circuit,like replacing a broken line, just match what I find. It rarely needs a flush and do not think it is in any maintenance schedule.
    Magura, who makes brake and hydraulic systems sells a red as well at most bicycle shops. Just a FYI...Baby Oil is mineral oil as well...but I would only use it if I was stuck somewhere with a rare leak and the drug store was the only place in my line of vision
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Available on Amazon
    Motorex KTM Mineral Oil Clutch Fluid 75 - 100ml. 575-010
    by Motorex
    $17.20
    https://smile.amazon.com/Motorex-KTM...rVL&ref=plSrch
    Help a guy out when he has a financial set back. Jeff B. could use a little consideration.
    Pretty darn pricey.
    Kevin Huddy
    Dot 4 and Mineral are totally incompatible. The wrong one used will absolutely destroy seals and other rubber parts in the system. When DOT 4 is specified the parts are compatible. When Mineral oil is specified the parts are compatible. The use of the other fluid will destroy the system and cost you a thousand or more to fix.
  1. 2005 k1200s
    By bige1340 in forum Wedge K-bikes
    Last Post: 01-08-2019, 01:54 AM
  2. 2005 K1200S will not idle
    By bbowers in forum Wedge K-bikes
    Last Post: 07-25-2017, 08:11 PM
  3. Just bought a 2005 K1200S
    By KillerBee in forum Wedge K-bikes
    Last Post: 02-28-2014, 02:44 AM
  4. 2005 k1200s considering vs. ??
    By romneg00 in forum Wedge K-bikes
    Last Post: 05-28-2011, 10:54 AM
