Results 1 to 10 of 10
Thread: Snowflake Rim Repair
    Hi again everyone-
    Latest question regarding the rebuild of my newly acquired ‘81 R65..
    Upon closer examination, it appears previous owner managed to hit a curb or something hard enough to cause what appears to be a flat spot on one side of the front rim, up on the top near the tire bead. I recall a similar issue with my ‘79 R100RS, and the BMW shop I used at that time sent it somewhere for repairs.
    I am not overly comfortable with the thought of repairing a rim with a bit of a flat spot, but do remember that it worked fine with the RS. Is this a fairly common issue with these rims?? The tire holds air, but is visibly flatter for about a two inch section.
    I would appreciate any feedback on this issue and perhaps recommendations for the repair work to be completed.
    Thanks!!
    Tom
    Liaison 20774's Avatar
    Tom -
    Probably best to get things taken care of...those rims are all that's keeping you from hitting the ground. My signature line has a section on wheels and rims, but Buchannon's and Woody's Wheel Works are places that come to mind. Maybe talk to them and see what they have to say.
    Nov 2005
    Calgary, Alberta
    I had a set of badly damaged Snowflakes repaired by our local wheel shop with no issues. Suggest you have your BMW tech check that the wheel is compliant to BMW spec after it comes back from the wheel shop.
    Rinty
    I would advise against straightening a cast rim. It is also contrary to BMW's recommendations to straighten any safety critical parts. A cast rim that has been bent will probably develop microcracks during the straightening process. These cracks can later grow in service with a bad results.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    You should contact "woodyswheelworks" and see what they say.
    Nick Kennedy
    Telluride Colorado
    Four years ago I had a bent front wheel from hitting a curb at speed. I made a appointment with Woodys. I rode my K-75 RT in there and took off my front wheel. 2 hrs later I had a straitened wheel, new tire and bearings for a very reasonable cost.
    Good service from those guys!
    Quote Originally Posted by nickrides View Post
    Thanks for this, I will contact Woody’s..!
    Quote Originally Posted by tlangman4 View Post
    Woody's will be very willing to tell you, after a look-see, that they will or won't straighten your wheel. I hit a chunk of 4"x4" wood and damaged a steel spoked wheel on an F650 severely enough the inner tube was visible from the side looking at the ding in the wheel. I sent if off to Woody's and they tried and decided they were not comfortable with the result. I had them lace a new rim to the hub with new spokes. My point is that if they don't like what they see they simply will not do it.
    Thanks, Paul. That’s good to know.
    In need of a nap. paper's Avatar
    Seneca, WI
    Tom,
    Not sure where you're located in WI, but the swap meet in Pecatonica, IL is coming up this spring and you might find a good replacement there.
    http://www.blackhawkbmwclub.org/inde...po-flea-market
    Why I remember when......
  1. Recalled Snowflake?
    By Darryl Cainey in forum Airheads
    Last Post: 07-02-2016, 06:42 PM
  2. Snowflake bearings
    By jsf14469 in forum Airheads
    Last Post: 03-04-2012, 03:46 PM
  3. Clearcoat Snowflake Rim?
    By King in forum Airheads
    Last Post: 11-02-2010, 12:34 PM
  4. Snowflake Part #
    Last Post: 05-24-2010, 02:27 AM
  5. Snowflake Wheels
    By jdbott in forum Airheads
    Last Post: 09-13-2008, 12:56 AM
