Results 1 to 7 of 7
Thread: Engine block rot?
    Engine block rot?
    Is it possible for there to be engine block rot? There’s a spot on the engine (clutch side) above the Id plate and below the frame joint where i found a layer of crud. When I tried to clean it, it felt soft and as I poked at it, it started to feel real soft. Is it possible that the engine block has a bit of rot? I assume not, but maybe a hole that was filled?
    Liaison 20774's Avatar
    I can't quite see the details. But the only thing black I can think of is either dirt that has gotten oiled up or possibly you're looking at the pushrod tube seals? Black "rot" doesn't come to my mind.
    Sorry, here’s a closer picture. It feels soft when I press on it.
    OK, can see it a bit better. Does it scrape off? Can you look at bits of it under a magnifying glass? Seems like it's just embedded road debris that has gotten more dirty and oily over time.
    Yup, will scrape it off and examine it. Hoping there isn't a hole or a crack there that was filled.
    Awww, that'll buff right out!!
    Vancouver, B.C. Canada
    Quote Originally Posted by armartel View Post
    _Highly_ unlikely in that area. I'm with Kurt here; try a good cleanup and see what's there.
    These engine cases are fairly thick and while surface corrosion on alumimun starts 5 seconds after it's machined it does not rot through. And if it does, in over 30 years of owning and working on them I have never seen it.
  1. Mysterious Hole Machined in Engine Block
    By KALTZG in forum Wetheads
    Last Post: 12-13-2018, 05:36 PM
  2. leak from engine block weep hole
    By rockster80 in forum Wetheads
    Last Post: 06-15-2016, 12:14 AM
  3. engine block heater?
    By nhlkats in forum Airheads
    Last Post: 11-19-2005, 09:13 PM
