Results 1 to 5 of 5
Thread: 2012 R1200 RT valve cover gaskets
    Hi, new member here.
    I managed to scrape the left valve cover on my bike. It has less than 1500 miles though is a 2012.
    I plan to replace the cover. The question is: replace gaskets or reuse? I have read on this forum that the gaskets can be reused, and this is a very low mileage machine.
    Thoughts ?
    Thanks in advance.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    The are designed to be reused.
    And, welcome to the forum.
    Kevin Huddy
    Registered User pappy35's Avatar
    Nov 2017
    Collierville, TN
    Welcome!
    Those gaskets are very durable and only need to be replaced if torn or otherwise damaged and leaking. Keep in mind that there are different different valve cover colors. I think there two, a dark-ish grey like those on my anniversary edition, and the more common silver (there may be others but I'm not sure offhand). Point is, just make sure you order the correct one for you bike. Check the MaxBMW or RealOEM fiches. I think RealOEM might key off your VIN number.
    '13 R1200RT 90th Anniversary Edition
    Registered User Dann's Avatar
    Dec 2013
    Laval, QC, Canada
    Quote Originally Posted by pappy35 View Post
    Welcome!
    +1
    I have 100,000 mi on my 07 and I'm still using the original gaskets.
    Daniel
    If you can park it, and not turn around to admire it before walking away, you bought the wrong one.
    2007 R1200RT - IBA # 56396
    Quote Originally Posted by JPICKENS123128 View Post
    Thoughts ?
    Thanks in advance.
    Welcome to German vehicles ... valve cover gaskets are reusable. (Yes, I know about VW Beetles) Just don't glue them on.
  1. Standard vs Silicone valve cover gaskets
    By 22600 in forum Airheads
    Last Post: 05-14-2015, 05:36 PM
  2. Silicone Valve Cover Gaskets?
    By Darryl Cainey in forum Airheads
    Last Post: 06-02-2013, 06:38 PM
  3. valve cover gaskets: install dry?
    By kwb210 in forum Airheads
    Last Post: 08-25-2009, 02:35 PM
  4. Valve cover gaskets????
    By brownie in forum Airheads
    Last Post: 08-24-2009, 02:13 PM
  5. valve cover gaskets need 2 replace every time?
    By nhlkats in forum Airheads
    Last Post: 01-02-2007, 10:27 PM
