Results 1 to 5 of 5
Thread: Switched on Power
Hybrid View
    Booger Man
    Nov 2018
    defiance, mo
    Switched on Power
    I have a 2018 R1200RT that I installed a Warm and Safe permanent dual contoller on the left side by the radio buttons. Where would I tap into to install a relay so that it only gets power when the bike is switched on. Right now it hooked direct to the battery. Thanks Tom
    on my 2016 there was a plug behind the left side front plastic that was switched power.
    AZ
    You can pull a trigger wire for the relay from the small fuse block under the driver's seat. One of those fuses is switched.
    MOA #107139
    RA #28511
    Wills Point, TX
    Quote Originally Posted by azgman View Post
    I used one of these, the switched one is 7.5a . See pages 14 and 156 in your bikes manual.
    Jay
    Registered User CABNFVR's Avatar
    Laurel Park, NC
    Just a tip, if you get switched power from a wire (as opposed to the fuse idea above) use a posi-tap. These little things are awesome!.
    "Have BMW. Will Travel"
  1. Where to find switched power for GPS?
    By Jambx in forum Oilheads
    Last Post: 06-26-2012, 06:40 PM
  2. Switched power lead
    By selyab in forum Oilheads
    Last Post: 12-04-2011, 05:34 PM
  3. K75 and switched power
    By PAULBACH in forum Flying Brick K-bikes
    Last Post: 10-06-2008, 02:39 PM
  4. Switched power?
    By REBECCAV in forum Oilheads
    Last Post: 04-12-2007, 01:23 PM
  5. R1200GS switched power
    By mwsedam in forum Oilheads
    Last Post: 08-23-2006, 04:13 AM
