Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: 4-Valve valve adjustment
    May 2008
    Western Massachusetts
    I'm wondering what you do-it-yourselfers have done regarding valve adjustment on the 4-valve bricks? I've done it myself on the old 2 valve bikes; there was once a kit with spare shims circulating the community. The 4-valve bikes seems to require the PITA cam removal, but even once you accomplish that, do you just go to the dealer to buy the shim sizes you need?
    The typical approach I've seen in scanning postings has been to ignore the issue altogether, and go on the theory that they never get too far out of spec. I've just measured mine (2003 K12RS w/ ~50k miles, never previously adjusted) and found all the exhaust valves in spec; three of the intakes were low. The worst was at 0.004 for a spec of 0.006-0.008.
    Thoughts?
    Registered User beemermyke's Avatar
    Richmond Hill, Georgia
    I'm going to lurk here on his question too... my son wants to do the same on his 96 K1100RS.
    Motorcycling is my passion because golf is far too dangerous!
    2016 R1200GSW
    May 2008
    I did some further research after my initial posting.
    There are some good online sessions on how to do the job. It doesn't look too tough. My big fear is having the cam chain slip a tooth and the timing going to hell.
    My local dealer has the valve buckets in stock (most sizes) for about $35 each.
    I'd still like to hear from those who have done it.
    Apr 2006
    Nibley, UT USA
    Unlike the 2V bikes, there are no shims so you have to install a new bucket. The service manual outlines the procedure for removing the cam. Once that’s out, you can remove the buckets one at a time and measure them with a micrometer, record the thickness, then calculate the size bucket you need to purchase to correct the clearance. Sometimes you luck out and can move an existing bucket to a new location to correct the clearance, and not need to buy a bucket. There is a chart in the factory service DVD that is useful for recording bucket sizes and calculating replacements or moves. But do always check the buckets with a micrometer, even tho their size is printed inside. The valve cover gasket can be re-used if in good condition, but needs a couple small dots of RTV at locations shown in the manual.
    It’s not a bad or terribly difficult job, just be methodical about it.
    Best,
    DG
    DGerber
    1983 R80ST — 1984 R80 G/S PD — 1993 R100GS — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT
    Liaison 20774's Avatar
    You've probably already seen this and since you've done it yourself a few times, maybe this doesn't help. It's for the K1200LT. The Illinois BMW Riders have some videos on checking the clearances...not sure what it says about what to do if things are out of spec:
    https://illinoisbmwriders.com/servic...learence-check
    May 2004
    boise, idaho
    4 valve valve check/adjustment
    I viewed the video cited above and found it very confidence-inspiring; fortunate because I'm looking to check and maybe adjust the valves on my K1100LT soon. The one part that does give me pause however, is indexing the sprockets when it's time to install the cams once again. The video references a OEM tool but the guy doesn't have/use it when he replaces the sprockets. Mess that step up and you could cause yourself a serious headache $$$. My plan is to take a lot of pix as I go in there to measure clearances and possibly swap buckets.
    May 2008
    Quote Originally Posted by walt3022 View Post
    Exactly my issue.
    I'm okay with tying the chain to the cam sprockets and pulling the cams off of them, but what about going back on?
    With the cams off the sprockets, and the chain tensioner backed off, what's keeping the chain engaged properly with the crankshaft sprocket? If a tooth slips there, what do you do?
    Apr 2006
    Nibley, UT USA
    Unless you’re really manhandling the chain that shouldn’t be an issue. Make sure you use good quality small zip ties on the cam sprockets, and at least two per sprocket.
    Best,
    DG
    DGerber
    May 2008
    Update: Inlet cam is out. Measured the three buckets I need. Dealer doesn't have the right size in stock so the job waits.
    All relatively easy so far, but the proof is in it's running when back together. Remounting the sprocket on the camshaft looks to the challenge. Time will tell.
    May 2004
    boise, idaho
    Can you give us more details? How many miles are on the bike? Do you know when the valves were last checked? Did you find any marks on the sprocket and camshaft to aid in putting them together? Do you need to adjust both inlet and exhaust valves?
    May 2008
    Sure, Walt.
    Most of questions were addressed in my initial post. 2003 K12RS w/ ~50kmiles. I've had it since about 10k miles, so I'm pretty sure the valves were never checked nor adjusted.
    I've now found three of the intake valves under spec. All the exhaust valves are within.
    With the exhausts good, I've only pulled the intake cam. That cam's sprocket is the only one I've taken off.
    A hole in the center of the sprocket slides over the end of the camshaft, held on by a bolt that threads into the center of the camshaft. The proper alignment of the two (timing) is assured by a pin that is permanently pressed into the face of the sprocket, protruding on the cam side of the sprocket. The camshaft has a groove machined on the edge of it's end face that allows the two to go together only one way (the pin goes into the groove).
    I assume the exhaust cam is done the same way, but since I haven't taken it apart, I'm just guessing.
    Only other thing I've noticed is about the hex that is cast into the camshaft. It's there to allow the shaft to be held from rotating while the bolt holding the sprocket on the end is torqued. Since it's an as-cast hex (not machined) it's size is not exact. They call it a 19mm hex, but it's smaller, meaning a 19mm open-end is oversized. I hate using wrenches that aren't a good fit on any hex as they tend to round the hex off. I haven't found a wrench that's a good fit. When it comes time to reassemble the cam/sprocket, I may try using an adjustable, just to get a better fit.
    May 2004
    boise, idaho
    Thanks for that update. I think it's very interesting that the valves that need attention are the intakes. Exhaust valves run hotter, and it's been my experience that they often are the ones that require adjusting.
    I bought a K1100LT with a mere 22 K miles on the clock last year. No real history came with the bike so I'm assuming the valves have never been touched. I will measure them soon, and I expect I'll be shopping for valve buckets too.
    May 2008
    FWIW, not only is it only intake valves that need reshimming, but curiously, all three are the righthand valve (when viewed from the bike's right side) of the two intake valves. Not sure if that means anything or is just a coincidence.
    On another note, I decided to add a new valve cover gasket as part of my reassembly, rather than risk oil leaks after it's all buttoned up. The new gasket costs $80! For a friggin gasket! Had I known I'd have planned to RTV the old one and reuse it.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    More important for preventing leaks at the V/C are the rubber bolt bushings. Since the bolts have a shoulder that bottoms out during installation, it is the resiliancy of the bushings that puts the pressure on the V/C and gasket. The gasket is usually good for many valve checks without replacement, but the bushings get hard and don't put correct pressure on the gasket causing leaks.
    The bolt bushing for the 4 valve Bricks is 11 14 1 461 475 ($3.61) You need 11 of them. 2 valve Ks take a different (and cheaper) bushing.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    Apr 2006
    Nibley, UT USA
    You will need a few tiny spots of RTV anyway, at the locations specified in the manual. Those dots are to help seal the sharp internal corners of the gasket at the hump. RTV anywhere else on the gasket will just create leaks. Those rubber gaskets can be re-used many times.
    Best,
    DG
    DGerber
  1. Setting valve adjustment on 16 valve engines
    By skesinger in forum Flying Brick K-bikes
    Last Post: 12-27-2016, 06:53 PM
  2. Valve adjustment R90/6
    By rbryson in forum Airheads
    Last Post: 12-10-2014, 01:51 AM
  3. Valve Adjustment
    By pschuyler in forum Airheads
    Last Post: 09-09-2009, 09:09 PM
  4. valve adjustment
    By arrowheadjake in forum Oilheads
    Last Post: 11-06-2006, 03:51 PM
  5. Valve Adjustment
    By Shelby in forum Oilheads
    Last Post: 04-09-2003, 02:21 AM
