Results 16 to 17 of 17
Thread: 4-Valve valve adjustment
    May 2008
    Western Massachusetts
    Job complete!
    Today I put in the new buckets to set the valve gaps, and buttoned the whole thing up. Problems I was concerned with turned out to be non-issues. The chain never slipped off the crank sprocket, and the one cam sprocket that I did remove (intake) was easy to get back on the shaft.
    I never really felt like had moved the cam chain tensioner, which is required in order to get enough slack in the chain in order to get the sprockets off. But apparently either I did, or since the bike had been sitting a month prior to the job, the oil had drained from the tensioner and it retracted itself.
    As mentioned previously I went with a new valve cover gasket. FWIW, the new one measured 0.020" thicker than the old one, which had been compressed in there for 16 years. I didn't use new rubber spacers on the valve cover bolts because 1) I didn't remember to buy them when at the dealer, and 2) after spending $250 on this job, I cheaped out. I'll watch for leaks.
    Of course now I have mastered this new skill, but it's on a bike that may never get its valves adjusted again. So if anyone's riding their K thru Western Mass and feels the need for a valve adjustment.....
    Nibley, UT USA
    Congrats, and enjoy the ride!
    Best,
    DG
    DGerber
    1983 R80ST 1984 R80 G/S PD 1993 R100GS 2004 K1200GT w/Hannigan S/C 2010 K1300GT
  1. Setting valve adjustment on 16 valve engines
    By skesinger in forum Flying Brick K-bikes
    Last Post: 12-27-2016, 06:53 PM
  2. Valve adjustment R90/6
    By rbryson in forum Airheads
    Last Post: 12-10-2014, 01:51 AM
  3. Valve Adjustment
    By pschuyler in forum Airheads
    Last Post: 09-09-2009, 09:09 PM
  4. valve adjustment
    By arrowheadjake in forum Oilheads
    Last Post: 11-06-2006, 03:51 PM
  5. Valve Adjustment
    By Shelby in forum Oilheads
    Last Post: 04-09-2003, 02:21 AM
