Results 1 to 6 of 6
Thread: 2005 K1200S Brake question
    Jan 2019
    Ingleside , Illinois
    Are the brakes on this bike linked ? How are the linked ? Thru the rear pedal ? Front lever ? How do they work ?
    Jan 2019
    What type of brake fluid does this machine take ? DOT 4 ?
    Someone elsee will need to address the linked question. But yes, it uses DOT 4 brake fluid.
    CENTEX USA
    Yes, linked. Front lever operates both, rear does rear only.
    Both our S's had minimal rear brake feel when using them solo, always wondered about how the bias was set. The first time I stopped at our roadside mailbox and applied the rear in gravel...I rolled past it by a long shot.
    The front pads are sintered metal, the rear isn't specified in the fiche as to composition spec.
    Left Coast Rider
    The rear pads on mine were sintered which tended to groove up the disc after a period of time. I replaced the disc and also changed pads to organic. End of problem with no downside. As well, the brakes are servo-assisted. Its critical that they be bled/flushed at regular intervals.
    Debbie's Servant Lee's Avatar
    SW Iowa
    Both our S's had minimal rear brake feel when using them solo,.
    Same thing for the K1300S.
    Lee
    2016 R1200RS
    MOA # 30878
  1. 2005 k1200s
    By bige1340 in forum Wedge K-bikes
    Last Post: 01-08-2019, 01:54 AM
  2. Just bought a 2005 K1200S
    By KillerBee in forum Wedge K-bikes
    Last Post: 02-28-2014, 02:44 AM
  3. 2005 R1200RT rear brake question
    By rstrick in forum Hexheads/Camheads
    Last Post: 05-27-2013, 09:59 PM
  4. 2005 k1200s considering vs. ??
    By romneg00 in forum Wedge K-bikes
    Last Post: 05-28-2011, 10:54 AM
