Results 1 to 7 of 7
Thread: R65 Brake Question
    R65 Brake Question
    Hi All-
    Just picked up an Ď81 R65 with relatively low miles but needs a lot of work. The bike has twin front rotors, something I thought wasnít available on the R65, but rather on the LS. So perhaps that is the modification as it appears to be stock equipment complete with Brembo gear. The master cylinder is shot, so trying to source a new one. Would anyone be able to tell me the size of m/c needed per mmís? Also, suggestion on where to source this part?
    Thank you!
    Tom
    Liaison 20774's Avatar
    If I'm reading this RealOEM page right for an '81 R65:
    http://www.realoem.com/bmw/enUS/show...diagId=34_0598
    it seems to suggest that the single ATE or Brembo master cylinder was 16mm. I checked a '81 R65LS and the parts fiche says 16mm as well...although I'm not so sure I'm reading things correctly. I know on my under-tank master cylinder, the size is actually stamped into the body of the part...maybe on yours??
    I suspect a dealer can still get a master cylinder. There are used part places in the link in my signature line. Plus, there are a couple of links there that indicate places that do resleeving.
    Nibley, UT USA
    Go to http://rubberchickenracinggarage.com and email the last seven digits of your VIN to Tom Cutter. He can set you up with the correct MC and will tell you how to tell which size you need.
    Best,
    DG
    DGerber
    1983 R80ST ó 1984 R80 G/S PD ó 1993 R100GS ó 2004 K1200GT w/Hannigan S/C ó 2010 K1300GT
    Mine had a 16mm, 15 is available and will give better leverage.
    The twin discs were an option, I had the same setup. But!
    Those ATE pistons are plated steel and are going to be pitted, the seals are also costly.
    82ish on used a brembo which has anodized aluminum pistons, that'd be the simplest swap/upgrade and probably the most economical.
    I adapted some Japanese discs and calipers but that is not a simple upgrade and is only economical if you make your own parts.
    Changed my R65 ATE calipers to Brembo F08 which replaced the ATE with no issue and gives better braking. $113 from mgcycle.com.
    Quote Originally Posted by kcoralj View Post
    Thanks for the information. I would rather go a different direction than the ATE, good to know Brembo will work.
    Quote Originally Posted by ftedv View Post
    This is great news! So the F08 will bolt on straightnaway without shims, etc.? Did you also purchase a new m/c as well?
    Tom
  1. ABS Brake question???
    By marshalguidry in forum Oilheads
    Last Post: 04-19-2013, 02:48 AM
  2. R90 Brake help / question
    By drpetecrocker in forum Airheads
    Last Post: 09-15-2010, 06:43 PM
  3. RT brake question
    By MildBill in forum Oilheads
    Last Post: 11-22-2009, 07:16 PM
  4. 75s brake question
    By jken1986 in forum Flying Brick K-bikes
    Last Post: 11-19-2009, 05:31 PM
  5. Another brake question.
    By squiffynimrod in forum Airheads
    Last Post: 03-20-2009, 02:00 PM
