Results 1 to 6 of 6
Thread: HaloCam M1 Motorcycle Dash Camera
    Apr 2016
    Seattle
    I have been using a Sena 10C Bluetooth camera for years now. I've loved it, but it is on its last legs. The battery has no life left and I think there's an internal memory error. I've been waiting for Sena to release the updated version, the Sena 10C Evo. Sena is about two years late on the Evo release, so I quit holding my breath on getting a replacement from Sena. When I bought the 10C, I only wanted a 20S and opted for the camera headset entirely on a whim. After buying it, I've been very happy with the camera. While I use it on trips, ninety percent of the time, I am using this helmet camera as a "dash" camera. My thinking is that if I am run off the road in a hit-and-run, my wife can tell the cops to check the camera for who the other party is. So I was looking for a trouble-free solution where I could get video from the front of my motorcycle as well as the rear. I also wanted something that would be powered by the motorcycle and not have a limitation of two hours as so many "action" cameras have before the battery runs out. Lastly, I wanted something discreet so I wouldn't have to worry about it being stolen. After doing a lot of research, I decided on the HaloCam M1. https://www.amazon.com/dp/B07D371DRF Cost was only $179.89. I highly recommend it.
    What attracted me to the HaloCam M1 was a couple things. First, it has 1080p cameras on the front and rear. Many of the older or less expensive cameras are only 720p. I don't know much about the cameras, but I do know that Sony is a good name brand, and they are using Sony cameras in the M1. That's a plus. The other big plus in my mind, was the wi-fi capability. Trying to aim your cameras without being able to see what you're doing in real time is a pain. The HaloCam M1 comes with a nice app for a smartphone that allows you to see what the cameras see in real time. You can also download your videos without touching the DVR unit, and even make changes to the settings from the app. It's slick. I was impressed with the HaloCam M1 from even the time I opened the box. The outside isn't glitzy. It actually has a touch of class to it, IMHO.
    When you open the box, you'll see the DVR unit along with the two cameras and the manual switch neatly arranged. To me, everything looked professional, not cheap. This was promising.
    Lift that packaging up and you'll see the cords neatly tucked away underneath. They use a short cord attached to each item like the cameras with a longer section to run from that camera to the DVR unit. Everything is color coded. You can't mess this up in the installation. Even the color coded plugs have only one way to plug them in. You can't mess it up. And they include heat shrink tubing that you can use to guarantee the connections are waterproof. They have thought of everything.
    Installation is straight-forward. Mount the front and rear cameras. Mount the GPS device they include. And mount the manual switch. Then find places on your motorcycle to hide the wires and plug them into the DVR. The last thing is to find a good power supply.
    The front camera is mounted on the black "lip" under the headlight. I doubt you can see it.
    The rear camera is a little more visible...but I doubt you'd notice it without it being pointed out.
    You'll want a power connection that turns off when the ignition is turned off. Otherwise, the camera will continue to record and you'll run your battery down eventually. I connected mine to the tail light circuit. I have a BMW, and there's a lot of concern about the CANBUS system having errors when you do this. I had no problems with mine. They also include a USB power connector that you can use to power the camera. Again, very well thought out.
    One note. The DVR does not have any built in memory storage. You'll need to supply your own SD memory card. Use the highest speed memory card you can buy for this, since you're recording from two cameras simultaneiously with sound. I used a Class 10, U1 card and the images were pixelated. With a Class 10, U3 card, all seems fine.
    What is it like in use? I've attached three screen captures. The rear camera shows a white vehicle merging behind me on the freeway. If you look closely, you can see another car to the side of it.
    The next picture shows the blue car rapidly gaining speed. Although there is a large open space to merge into, it is clear he is not merging there.
    The last picture shows the blue car cutting in front of me. BTW, the only reason he had that much space to merge into, was that I wasn't going to "fight" for my space and I backed off. Right after he moved in front of me, he cut over two more lanes in heavy traffic. If there had been an accident, the video shows a seamless capture of his actions from the rear camera to the front camera.
    I haven't tested this yet , but if there had been an accident, the camera has a vibration sensor that locks the video so it isn't overwritten.
    This is not an "action" camera, yet one of the sales people at Cycle Gear mentioned that the video I showed her was as good or better than her GoPro. I don't know if I'd go that far. But it is good.
    As a "dash" camera though, I'd rate it as exceptional. The quality of everything is excellent, and the price is great.
    I have only one nit-pick... When you mount the cameras in their mounts, they are still a little lose when the screw is tightened all the way. The "fix"...just use another washer on the inside of the two arms of the mount that holds the camera and it'll tighten just fine. That is really minor. You'll see what I mean when you mount yours.
    Lastly, I have to make a comment about the HaloCam customer service. It is exceptional. I notice that of the previous reviews, one person had issues with his camera. I did too initially. I contacted them and they were outstanding in resolving my issue. I don't know when I've had better customer service. They definitely stand by their product.
    Chris
    Elnathan - 2014 BMW F800GT
    IBA# 49894 True Rounder = 0-20's - Rounder -- to -- 100's+ Red Hot Rounder
    John 14:6
    Jan 2016
    Central Illinois
    M1 Cam
    Thanks for info system looks great it's a shame we need one. It seems like when riding or driving not seeing someone doing something stupid is the exception. That being said perhaps a update that edits out stupid stuff we do when riding with the system ( my bad removal edit ) what would be nice some way to tag or bookmark the oh crap moments that we have, than automatically send them to us later as reminders to not do that again.
    Again thanks for info!
    Mansfield,MA
    Nice Chris
    Mod Squad
    2009 F800GS 1994 TW200
    bored, bored ... dlowry's Avatar
    Dec 2005
    Snow Country, ON, Canada
    Looks like a very clean install. Is there a way to remove their watermark from the video? To me, that's the only bugaboo I see.
    Dave...
    15 R1200 RT, 12 G650GS
    83 Suzuki XN85 D Turbo
    Apr 2016
    Seattle
    Quote Originally Posted by 179212 View Post
    There's a manual switch that when pressed will lock that video file so it isn't overwritten.
    Chris
    John 14:6
    Additional review on Two Wheel Obsession
    THe Halocam M1 has been pretty thoroughly reviewed on Two Wheel Obseesion you tube channel. Summary: He liked it as it is thhe only one he tested so far that actually worked out of the box and it has all the basic functionality he was looking for. The only negatives were the horrible Chenglish translation and the loose bracket which was reported here. My personal opinion as one looking for one of these style cameras is I would like to see a more waterproof recoreder and get rid of the LCD screen as the Innovv K2. Have heard rumor that Halocam sort of put their toe in the water with this unit to see what the resonse would be and will be making another one soon with improvements garnered from customer request and inputs.
  1. Gremlins in my dash
    By priceranch in forum Motorrad
    Last Post: 04-24-2018, 12:28 AM
  2. Innovv K1 Moto Dash Camera Review
    By ppalac in forum Gear
    Last Post: 04-06-2016, 04:40 PM
  3. Enroute camera/video camera thoughts...
    By irishspirit in forum Gear
    Last Post: 04-19-2011, 04:04 PM
  4. Melting LT Dash
    By abrown in forum Campfire
    Last Post: 02-22-2008, 08:10 PM
  5. Digital Dash on a /6?
    By eosnut in forum Airheads
    Last Post: 11-20-2007, 05:20 AM
