Results 1 to 15 of 23
Thread: Brutal Starting Issue- 1983 R80 GS
Hybrid View
    Hi folks,
    I'm a Nor'easter and it's just starting to really get cold. My 1983 R80 GS is in the garage and I've been working on it slowly. Last week, after a particularly cold evening with no tender on it, I went to start it in the morning and it wouldn't turn over, the ignition just started to slow down until there was a clicking. I figured that the battery was bad, bought a new PC680, installed it and that solved the problem. Last night, I did the same thing, left the tender off, and went to start it this evening and same thing happened. The lights come on, the engine will start to turn, but it sounds like on the first, second and maybe third try, there's just not enough juice to get it to turn. After the fifth or sixth try, it starts running low and dying out and then, after a a few more tries, it just starts clicking. Obviously I'm draining the battery, but a few questions here:
    1) How do I know if have a starter or alternator problem?
    2) Is it possible I have a faulty battery? If so, how can I know?
    3) Do I need to keep a tender on the bike every evening in the cold weather? I ride deep in to January and have never had this issue before.
    Thanks.
    Jan 2017
    Windsor PA
    I would charge battery ,disconnect battery from bike maybe ground wire if yours is easy to get to. then next day connect it and see if battery is low again. If not, then something is draining it while its sitting .thats when the fun begins trying to find what draining it while key is turned off.Check battery wires and other hot wires for signs of wear that might be touching ground.
    Liaison 20774's Avatar
    Welcome to the forum!
    Here's an article on starting troubles on Snowbum's site: http://bmwmotorcycletech.info/startingprobs.htm
    1) The alternator really doesn't come into play when starting the bike. Connections to the starter could be corroded resulting in little transfer of current. Same thing could be said of your battery cables. Make sure that the negative attachment of the battery cable to the back of the transmission is tight...don't over tighten the bolt however. Not sure when the older Valeo starters were used, but it's possible if you have one of those, the inner field windings can come loose which drag and can lock up the armature.
    2) You can try to jump the bike using a known good battery...usually just hook up the donor battery but don't have the donor vehicle running. You can remove the battery and take it to any reasonable auto parts store...they can load test the battery.
    3) A tender can certainly help in most situations. If you've been able to start the bike in past years under similar conditions, then something has changed.
    Thanks for all the replies. A couple of things I tried:
    1) Successfully jump started with car battery
    2) Put the tender on last night and it started right up this morning
    3) Took the tender off today when I left for work this morning, got home this evening, and battery was too low to turn starter
    4) There is a leak in oil pressure switch (which might be causing a short?)
    5) I took the tank off and observed that the starter relay is clicking and blinking green, but nothing happens after that (here's a video: https://ve.media.tumblr.com/tumblr_p...vPJ1spe6y3.mp4).
    I just replaced the battery last week. Could the battery be faulty? Could the starter relay be faulty?
    The battery could be faulty. The best test is to disconnect it and charge it fully. Then let it sit a day and see if it has self discharged.
    It could be some circuit in the bike causing battery drain. Disconnect the negative cable and insert an VOM on the amperage setting between the cable and the battery post. See what the amperage is with the bike just sitting key off. It should just be a miniscule number of milliamps.
    Report back.
    With engine running at 3K RPM or so, what is the voltage across the battery terminals? Should be well north of 13.5v.
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    Exactly what "tender" are you using? Is it approved for the PC-680?
    http://www.odysseybattery.com/docume...V_chargers.pdf
    Update
    Thanks for the suggestions. I ordered a VOM. It will get here today and I'll update you when I run the tests you suggested.
    I kept a tender on it last night and the only change is that the clicking is faster, which you can see here: https://ve.media.tumblr.com/tumblr_p...8fS1spe6y3.mp4
    Tender
    Interesting question about the tender which I never thought of. I'm using (but I don't see it on approved list): https://www.amazon.com/gp/product/B00068XCQU
    Coincidentally, it's blinking red and green now (indicating that the battery is over 80% charged, but it's been on all night- so it should be fully charged.
    Update
    Quick update: I disconnected the negative cable and there were no amps when I connected the VOM.
    I just took the battery off and it was at 10.94, so I'm charging it now and we'll what happens after it's fully charged.
    Jun 2011
    N.E. Ohio
    That battery wants 6 amps minimum at 14.7V to keep it at full charge. I have 3 PC-680's.
  1. Starting issue has me stumped
    By mieczkow in forum Flying Brick K-bikes
    Last Post: 01-28-2016, 11:58 PM
  2. K75c Starting Issue
    By Niles1 in forum Flying Brick K-bikes
    Last Post: 12-12-2015, 08:15 PM
  3. Starting Issue
    By 217don in forum Oilheads
    Last Post: 08-10-2014, 06:25 PM
  4. Starting Issue
    By Slablog in forum Oilheads
    Last Post: 05-08-2008, 08:06 PM
  5. '04 GT starting issue
    By hcmiller52 in forum Flying Brick K-bikes
    Last Post: 05-04-2007, 03:49 AM
