Results 1 to 3 of 3
Thread: 49L Topcase Disassembly
    Peter D dunc723's Avatar
    Aug 2012
    Nashville, TN
    I have a BMW 49L topcase on my 2006 RT. I want to install tail/brake/turn signal lights on the lower half of the case and run the wiring in the space between the outer shell and inner shell. Is it possible to disassemble the two? I tried removing all the screws on the inside and could sort of separate them, but stopped for fear severe damage.
    Has anyone done that? Any advice?
    Pete
    Pete
    When life throws you a curve, lean into it. (Seen on a t-shirt at MotoGP Indy)
    '06 R1200RT, '12 F650GS, '04 K1200GT (Sold)
    Are we there yet? tonyfr's Avatar
    Apr 2007
    SAT - LAX
    I had to separate mine due to a latch issue. If you take pictures as you go along, it not too intimidating. This is what it looks like on the inside (not electrified). You also have to make sure the long silver rails are in the slots correctly. LINK
    BMWMOA #62 / BMWRA #77
    2009 K1300 GT
    1984 Kawasaki ZX750-E1 Turbo
    1990 Kawasaki ZX600R
    Aug 2012
    Nashville, TN
    Is it hard to separate? Or is there some trick? I got it started but ran into a lot of resistance.
    Pete
    Pete
  1. Help!!! Headlight disassembly for a 16 rt
    By poco183 in forum Wetheads
    Last Post: 12-29-2018, 01:27 AM
  2. Disassembly of Headlight Switch
    By 98lee in forum K-bikes DIY/Tech Library
    Last Post: 08-31-2015, 08:26 PM
  3. FYKRT - gas cap disassembly
    By mneblett in forum Flying Brick K-bikes
    Last Post: 12-12-2010, 01:00 PM
  4. final drive disassembly?
    By grw in forum Flying Brick K-bikes
    Last Post: 05-21-2010, 03:21 AM
  5. Disassembly R65LS Questions
    By kentuvman in forum Airheads
    Last Post: 03-02-2009, 03:49 PM
