Results 16 to 26 of 26
Thread: Garmin discontinues BaseCamp Support
    Jan 2016
    Central Illinois
    Mapping
    Not having much experience with gps and none with basecamp my WAG, targeted advertising is somehow part of this decision
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    Is BaseCamp still available for download?
    Joe
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Nibley, UT USA
    Quote Originally Posted by 61996 View Post
    Joe
    Yes, on the Garmin site under “Software”.
    Best,
    DG
    DGerber
    1983 R80ST — 1984 R80 G/S PD — 1993 R100GS — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    Joe
    Yes, Basecamp is still available for download and still supported.
    The original title to this thread is misleading and should be corrected.
    All versions of Basecamp are available >>here<< It is still recommended that you install 4.6.2 instead of 4.7.0 due to some issues, until Garmin releases the fixes.
    Pat
    Ride Safe!
    '16 RT
    Central Ohio
    All I can easily find on the Garmin site is version 4.7, which is a functional down grade from version 4.6.2. Also, there have been reports of problems transferring data to some devices.
    Version 4.6.2 can be downloaded here: http://www.gawisp.com/perry/mapsource/. Save a copy of the installer in case you accidentally "upgrade" to 4.7.
    Some web functions and Garmin cloud storage will not work because Garmin discontinued their services, but 4.6.2 will still let you preview your routes with Google Earth.
    Edit: Guess I need to type faster...
    Larry
    2006 R1200RT
    Mansfield,MA
    Quote Originally Posted by Visian View Post
    If all you want is directions or a moving map showing your current location, those solutions are fine.
    If you want to plan and/or share routes that go into far-reaching areas, these solutions are not adequate.
    I was having tea and hard-tac with Chris Columbus the other day..........
    Mod Squad
    2009 F800GS 1994 TW200
    Nibley, UT USA
    Quote Originally Posted by patm View Post
    Discontinuance of development would imply there will be no fixes, patches, etc. for the 4.7.0 version. In Garmin-speak, I think “supported” means only that they will answer any questions you may have, and will assist you in using or installing the software, but that’s about it. Pretty much the same routine they followed with MapSource.
    Best,
    DG
    DGerber
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    Come on now, Chris Columbus found his way here without GPS, and even managed to avoid falling off the edge of the world while doing it. How many "New Worlds" have you discovered with your GPS ???
    Friedle
    Ride fast safely
    Quote Originally Posted by lkraus View Post
    Those are all PC exe's... do either of you happen to know where a Mac-compatibly 4.6.2 is available? I really miss that Google Earth preview feature.
    Mansfield,MA
    Quote Originally Posted by Friedle View Post
    Friedle
    You seem to have missed the part of the conversation I was replying to.
    Mod Squad
  11. #26
    Mar 2016
    Montreal, QC
    You can use other cloud storage instead of the Garmin cloud by following these how to instructions: Instructions for Windows
    The equivalent for Macs: https://forums.garmin.com/forum/mac-...46#post1357946
    Pat
    Ride Safe!
    '16 RT
  1. Garmin Zumo 396 / BaseCamp Route plotting Issue
    By freestoneriver in forum Gear
    Last Post: 08-25-2018, 04:19 PM
  2. Learn Garmin BaseCamp Tutorial Videos
    By Norwood in forum Gear
    Last Post: 03-20-2018, 06:38 PM
  3. Garmin Basecamp / GPS / Google Maps
    By bmwclub294 in forum Campfire
    Last Post: 05-22-2017, 01:28 PM
  4. Basecamp for Garmin
    By Wethead in forum Gear
    Last Post: 02-18-2015, 02:29 AM
  5. Garmin BaseCamp Question
    By sickticket in forum Gear
    Last Post: 04-23-2013, 05:23 AM
