Results 1 to 5 of 5
Thread: BMW Audio System Question
    DesmoDerek desmoderek's Avatar
    Aug 2016
    Indianapolis, IN
    With the Audio System on, and scrolling through the Source Menu (SRC) there is an option for Playlist. I have tried exporting an iTunes Playlist in unicode.txt , plain text, and all the other options (M3U, M3U8, XML) but none of them show up in the Playlist menu on the bike.
    Does anyone know what format the system recognises?
    Andrew
    MOA # 210167
    Mars Red RT Silk White Multistrada 950 Bonbler Black i.e. Bonneville Black Scrambler (carb)
    Sep 2009
    Chestnut Hill, MA
    I think a simpler way to handle the issue is to get a 16GB USB 2.0 (not 3.0) flash drive and plug it into the USB slot in the RH compartment. I've never noticed a "Playlist" option in the menus on my 2015RT. I use a program called "M3Unify" to create the USB files. It seems to work very well.
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    Watching the sunrise outdoors statistically increases your odds of having a good day. And needing a nap after lunch.
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by desmoderek View Post
    I've never had any luck copying an iTunes playlist to anything other than another Apple product.
    Lee
    2016 R1200RS
    MOA # 30878
    While this does not directly answer your question, I use a USB stick with lots of music on it in .mp3 format, and set it to play at random.
    Because my music is sourced from all over the place, it can play back at different volumes, so I run a little program called "MP3Gain" over the files that evens up the output volume before I copy them to the bike's USB stick.
    I use earbuds, rather than bluetooth helmet speakers, to listen to music. I use a USB drive with music, a small iPhone, an iPod, and SiriusXM to listen to music. I described my set-up under the K1600 section (as that is where the question first arose). The volume adjustment and song selection is done using the wobbly wheel on the left-hand side handle bar. A link to that discussion follows -
    https://forums.bmwmoa.org/showthread...ith-Blue-tooth
  1. Replies: 16
    Last Post: 09-04-2017, 07:58 PM
  2. Need Audio System Manual 2013 RT
    By beemergirl in forum Hexheads/Camheads
    Last Post: 11-16-2015, 05:33 PM
  3. Audio system and ear buds
    By dirtyjimmy in forum Hexheads/Camheads
    Last Post: 07-26-2011, 06:32 PM
  4. Best Headphone and Audio system
    By jwwinzeler in forum Hexheads/Camheads
    Last Post: 06-26-2008, 06:59 PM
  5. J&M CB Radio/Audio System
    By noahjo in forum Oilheads
    Last Post: 12-02-2004, 02:48 AM
