Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: Cyclops LED Replacement Kit
    Sep 2009
    Chestnut Hill, MA
    Has anyone tried the Cyclops LED replacement kit for the R1200RT? It seems to come in three models, and seems to include all the parts needed. The descriptive data indicates that all the bulbs are replaced and every part of the kit fits under the BMW caps. Here's a screen-shot of the information from the Cyclops website:
    Here's more information, again from a screen-shot:
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    “So often times it happens that we live our lives in chains
    And we never even know we have the key”
    Liaison 20774's Avatar
    There are some previous threads shown in the Similar Threads pane at the bottom of the screen. You can start there until others weigh in...
    Sep 2009
    Chestnut Hill, MA
    Thanks Kurt. I saw those but was hoping someone had used the total kit approach on a 2015.
    Wills Point, TX
    I don't understand why the RT kit is for 2013-2015, 2015-2018? I'm not aware of any headlight changes from 2014 forward.
    Jay
    Poco183 poco183's Avatar
    Oct 2016
    Brighton, Mi
    I bought the kit for my 16 RT. It has everything you need. I chose Cyclops because I had a set of their lights in my 09 RT and I loved them. The company is very good to deal with if you have questions or problems. They have always taken very good care of me.
    Life is 10% what happens to you and 90% how you respond to it.
    Booger Man
    Nov 2018
    defiance, mo
    Quote Originally Posted by poco183 View Post
    How was the install on the kit ? Could you do it without a bunch disassembly ?
    Oct 2016
    Brighton, Mi
    Quote Originally Posted by 178592 View Post
    Well, it depends on how you try to install them. Cyclops suggests you take out the headlight assembly, but they also say it is possible to install the lights without removing the headlight.
    If you choose not to remove the headlight, the process requires patience and relatively small hands. It's not impossible, but you will have to work slow. The low beam light is accessible from sitting in front of your bike and reaching up behind the headlight. Removing the old headlight is a snap. Before installing the new headlight, make sure you read an understand the instructions. There is a ring on the new bulb which needs to be placed inside the assembly and secured with the wire before you install the new bulb. Before you try to place the ring in, put a piece of duct take in the gap between the headlight assembly and the plastic housing. This will prevent you from dropping the ring into the headlight assemble like I did and it is a PITA to fish out.
    The high beam lights are pretty straight forward. You only have to remove the speaker covers and speakers. Once again, small hands and patience are a key.
    If you decided to remove the headlight, it's not too bad. There are a few more pieces to take apart, but it's not a long process.
    I love Cyclops Lights and their customer support. The lights are worth the $200.
    I've tried to attach a copy of the instructions but I continually get an error message. If you would like a copy, send me a message,
    Booger Man
    Nov 2018
    defiance, mo
    Thanks for the info. I’ll let you know.
    I have a 2015 RT and I purchased the kit (Hi and Low beams) and I am impressed with the performance. I had previously purchased a single main headlight from Cyclops in 2015 and found the single LED superior to the standard incandescent bulb. The earlier version put out much more light than a standard bulb and the color of the light seemed to provide better contrast to anything on the road and shoulder. The downside of the earlier version was that the beam cutoff was not as sharp as the standard bulb and when I flipped on the brights, there was a icon that popped up that meant that the canbus thought that one of the bulbs was burnt out. Neither the beam pattern nor the canbus error message were big issues.
    When Cyclops came out with a newer version of the H7 bulb and the position of the LED better replicated the position of the filiment in a standard H7, I decided to talk with Cyclops. They told me that with the new version of LED, the cutoff pattern would be very similar to that of the std bulb. Also, the difference in the kits is based on whether or not there is a load resistor included. Evidently, there was a change in either the lighting circuit or the canbus sensitivity sometime during the 2015 production cycle. Prior to 2015, no load resistor is needed. After 2015, a load resistor is required when installing the main H7 replacement - otherwise you will get a canbus error message when you use the Hi beam.
    I purchased the kit and in an afternoon, pulled out the headlight assembly changed out all of the bulbs and reassembled everything. This new version has an imroved beam pattern, the main beam has a little more light, and now the Hi beam is even brighter and no error message. I think it's a great product.
    Sep 2007
    Chesapeake, VA
    Intermittent interferrence.
    Not being much of a wrench turner, I purchased the LED's at the dealer and had them do the install. I'm not sure if it was a full kit or what but they replaced all three bulbs. I immediatley lost FM reception. I returned to have the bulbs swapped out with a newer version, where they also added something to the wires to mitigate the RF interrferrence. It work great going home - 3 hours through the woods is never bad. However a couple days later I fired her up and all I got was a hailstorm in my headest that lasted several days. Today it fired up clean as a whistle, for a few minutes, then went back into storm mode. I'm thinking something, like a ground, is just loose under there. I'm not sure how to trouble shoot this so I'll have to call 'em back to see what my options are.
    Registered User skibumwi's Avatar
    Jul 2016
    Milwaukee
    GOOD, I'm glad I'm not the only one who did that, mines still in the housing somewhere....
    Ski
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    At the National we had one put into Patricia's Vulcan.
    Great people to deal with and a super great product.
    She go a newer version that runs the high and low LED on high beam, it just cuts power to the low beam LED.
    We drove 700 miles home and a lot in the dark and it made a huge difference to her.
    She did not report any issues with the Sena 30K FM or in any of our pairings so it must be a canbus thing.
    I am sold on them and would recommend them to anyone based on the improvement over the stock bulb.
    I did ask him on longevity and he said we like to be honest and tell people 3-4 years. I can afford 89 bucks every 3-4 years to keep Patricia in LED lights.
    Here is a great link to a install.
    https://www.bmwlt.com/forums/rt-seri...-wetheads.html
    Lee
    2017.5 R 1200 GSW
    I am pretty close to ordering one of these kits for my '16 RT. However the current exchange rate with the Aussie Dollar makes it a pretty expensive set of lights.
    Thanks to LFarling for the link to the installation procedure and review.
    Booger Man
    Nov 2018
    defiance, mo
    Had my local dealer install the 3 pack last week. Have not had a chance to ride in the dark yet . Install took the dealer about 4 hrs. They quoted 1 hr. and stood by their quote. They said no one else will get and 1hr deal I have a 2018 RT
    Registered User pappy35's Avatar
    Nov 2017
    Collierville, TN
    Save your money, I installed these and they've worked perfectly.
    I had a set of ADVMonster and Cylops H7's so, yes, I've spent a great deal of money testing. These work perfectly, have no bulky modules to try to bury in the housing, and no CANBUS errors at all. They come in packs of two so, for the cost of ONE Cylops/ADVM you can buy all three plus have a spare.
    PS - I'm not ripping Cyclops. A wholeheartedly agree that Daryl and crew are wonderful and very customer-focused.
    '13 R1200RT 90th Anniversary Edition
  1. Cyclops LED for 2010 R1200RT
    By etiennelau in forum Hexheads/Camheads
    Last Post: 10-21-2018, 03:49 PM
  2. Cyclops H7 Installation 09 RT
    By will3hawks in forum Hexheads/Camheads
    Last Post: 09-10-2017, 01:56 PM
  3. Cyclops H7 Headlight bulb installation 2009 R1200RT
    Last Post: 07-30-2017, 02:18 AM
  4. Cyclops LED Bulb Replacement
    By BC1100S in forum Oilheads
    Last Post: 05-02-2017, 08:12 PM
  5. Replies: 5
    Last Post: 10-16-2016, 04:35 PM
