Results 1 to 15 of 16
Thread: 2015 GS tire change tool recommendations
    I recently traded my '09 RT for a 2015 GS and found Anakee Wild's on sale even though the original Anakee 3's only have 3500 miles on them. I've changed pickup and bicycle tires, but this will be my first time to change motorcycle tires and will need to buy some new tools (a guy needs an excuse for new tools, right?). I figure they will pay for themselves after two or three sets of tires.
    I know I will need a balancer with an adapter for the rear wheel. Any suggestions what to look for and what to avoid?
    What size Hex socket do I need for the front axle? I've seen posts showing 22mm for older models, but have not found a post showing the correct size for the 2015 GS. I tried the reverse spark plug socket trick I saw on some posts, but none of the ones I have fit, so I might as well buy the right size Hex socket.
    I'd originally thought to use the kickstand foot to break the bead as I saw on some posts, but am thinking it might be better to have a tire changer that I can keep using. I need to keep the cost down, but I also want something easy to fold up and store. Any suggestions?
    Tips and tricks from your experience are also appreciated!
    I have an inexpensive, yet very effective, Harbor Freight tire changer... but for the GS tubeless wire wheels I had to make some adapters. I don't have the measurement info for those handy, but if you're going to change your tires yourself a lot I recommend the NoMar changer. Its clamps fit the GS thick rim edges and because they are a composite plastic, the are less likely to scratch your wheels than any metal clamps. I don't know which model of NoMar to recommend, call them and ask... they will steer you straight.
    Both of these gadgets will break the bead on your tire... but if you're going to do it by hand, try these Motion Pro Tire Levers. They hook together to form a wedge and break the bead (it is *not* easy) and then you can use them to remove the tire from the rim.
    Breaking the bead with your sidestand is difficult and dangerous (since your rear wheel will be off the bike) and trust me... the machine is *much* easier.
    I also like Motion Pro tire spoons. You can buy one with the right size socket for your axle (which I don't know off-hand!... I have an 1150 GS)... just measure it with a metric ruler. You should have a wrench in your tool kit... but these days with the latest BMWs, you never know!
    Remove the stem with a Motion Pro Stem Tool
    Be sure to use tire lube, NoMar or RuGlyde are both excellent products.
    Spring for the tire machine.... damhikt!
    Ian
    ps => and be sure to join the GS Giants!
    __________________________________________________ __________________________________
    '67 Trail 90 || '86 R80 G/SPD+ || '97 F650ST || '00 1150 GS || '07 Xchallenge || '13 CB500X || '14 Grom
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Good info from Ian. Iíve been using a NoMar changer for eight years and it works well. Two things that make the job easier are lubrication and heat. A dry cool tire can be a bear to get on or off. If your bike has the BMW tire pressure monitoring system, then extra caution must be taken to not damage the sensor; it is attached to the valve stem inside the tire. Check You Tube, there are many videos showing how to change a tire with tire irons, or a Harbor Freight changer or a NoMar.
    Kevin Huddy
    Mansfield,MA
    Warmth....warmth makes it all go mo'betterer. A hot sunny day-
    Mod Squad
    2009 F800GS 1994 TW200
    Jul 2007
    Big Sky Country
    I use a set of these. They make the tires like bubble gum.
    Kevin Huddy
    Quote Originally Posted by akbeemer View Post
    Unlike Montana, here in Texas we generally have enough warm sunny days that a wheel/tire out in the sun soon gets warm enough. Usually.
    Jul 2007
    Big Sky Country
    I changed four tires on our bikes in the past few weeks here in tropical Montana. Leaving the tires outside resulted the formation of ice crystals. My tire changer is in the unheated part of the shop, so I get the tires nice and hot with the warmers in the heated area, then hurry out and do my work with alacrity.
    Kevin Huddy
    Wills Point, TX
    I too have a No Mar (I like the mojo bar to install https://www.mojotiretools.com/mojoweb.htm) and YES warm tires make all the difference unless you have a pneumatic tire changer. If you are considering tire warmers and a new tire changer such as a No Mar or Coats why not go for https://www.gregsmithequipment.com/A...1-Tire-Changer
    Jay
    Oh, I forgot.... lay your wheels and new tires out in the sun for a half hour before starting... *unless* you live in the great white North!
    Jul 2007
    Big Sky Country
    In 45 minutes to an hour these things will get a tire so hot that I cannot handle it without gloves. A friend measured tire temperatures after heating in the sun and using warmers. The warmers got the tires about 40 degrees warmer than the sun.
    Kevin Huddy
    kellenbenz kellenbenz's Avatar
    Dec 2012
    Tyler, Texas
    After 10 years of changing my tires with a Harbor Freight changer and asking the wife to help, look what she bought me. I think she was sending a message.
    IBA 45658 MOA167437
    728,482 miles on touring motorcycles
    Total BMW miles 490,099
    Mar 2011
    socal
    Google Mark Parns, he has all the tools required to remove front wheel and balance both front and rear wheels
    Jim
    Quote Originally Posted by t6pilot View Post
    Jim
    gah... forgot that. These work well with a simple pair of jackstands.
    Mansfield,MA
    Quote Originally Posted by kellenbenz View Post
    Does she have a sister?
    om
    Mod Squad
    Jul 2007
    Big Sky Country
    I have long said that if you seem to be the guy that never gets invited to parties, has no friends and no one ever calls, then get a tire changer. Suddenly you will have friends you never met, strangers will appear at your door with tire in hand and your phone will not stop ringing. I imagine that if you have a pneumatic tire changer you will make the Hollywood ďAĒ list.
    Kevin Huddy
  1. Brake Bleed tool, recommendations?
    By bikerfish1100 in forum Motorrad
    Last Post: 07-13-2016, 11:15 PM
  2. Tool Kit recommendations?
    By skibumwi in forum Wetheads
    Last Post: 07-13-2016, 12:09 AM
  3. Tool kit for a 2015 R1200GSA
    By 1der in forum Wetheads
    Last Post: 08-16-2015, 10:51 PM
  4. Special tool for 1100RT Rear tire change?
    By Onebeemer in forum Oilheads
    Last Post: 08-25-2008, 02:52 PM
