Results 1 to 13 of 13
Thread: BMWs and On-Board Diagnostics (OBD)
Hybrid View
    May 2007
    Western NY
    The following is the text of a letter to the editor I just sent to the MOA. It expands on the use of automotive diagnostics on BMW motorcycles.
    "Wes Fleming’s Torque of the Matter column in the December 2018 Owners News is a bit dated. Near the end of the article he states that ”more motorcycle makers are anticipating the day when all bikes have to have OBD-style connectors and their ECUs will need to speak a common dialect.” That day is already here. European Union (EU) Regulation 168/2013 requires standardized on-board diagnostics for all motorcycles sold in the EU. Specific requirements include use of the 16-pin automotive OBD connector (later amended to allow a smaller 6-pin motorcycle-specific connector), use of any of the standard automotive data communication protocols, and use of standard automotive diagnostic trouble codes (DTCs). Phase-in dates were January 1, 2016, for new motorcycle types, and January 1, 2017, for existing types. This is the reason all new BMW motorcycles have 16-pin diagnostic connectors.
    BMW’s use of automotive OBD technology on their motorcycles goes back even further. In a February 2013 posting on the S1000RRforum.com forum, one individual described connecting an UltraGauge OBD-II data reader to his bike. He jumpered wires from the 10-pin round diagnostic connector on his bike to an automotive 16-pin connector to mate with the UltraGauge. He was able to read several additional data types available from the ECU. His S1000RR uses the KWP 2000 automotive OBD protocol. This past week I was able to do the same thing on my 2007 R1200ST. I used a GS911 female adapter cable to interface between the bike’s connector and the UltraGauge. I too was able to view several items of data, again using the KWP 2000 protocol. I was also able to connect my Actron CP9695 scan tool using the same adapter cable and read data and trouble codes. Unfortunately, all my testing was done engine off since my bike is in storage for the winter. I’ll do more testing when the spring thaw comes here in western New York."
    Karl
    2007 R1200ST
    Mansfield,MA
    It would be interesting to hear more about all this......Including the possible years this method will work on
    Mod Squad
    2009 F800GS 1994 TW200
    May 2007
    Western NY
    I suspect the data readout function using the UltraGauge or an OBD-II scan tool would work on any bike with a round 10-pin diagnostic connector or a 16-pin automotive-style connector; in other words, any bike compatible with the GS911 tool. There may be some items reported by one device but not by the others, however.
    Fault codes may be another matter. The UltraGauge and scan tools, being designed for automotive use, expect fault codes formatted as a single letter (U, P, B or C) followed by 4 digits. I have only seen GS911 fault codes reported in pure numerical format. Exactly how BMW sends them over the diagnostic line is unknown. Currently my UltraGauge and scan tool report no faults present. To verify the fault code reporting and clearing functions I will need to trigger a reportable fault. Any suggestions?
    Karl
    2007 R1200ST
    Mansfield,MA
    The least invasive code I can think of would be ABS- perhaps removal o a sensor from a wheel and, after safely securing it, have a ride around the block.
    That said, I’m not one for messing with things that are not broken Perhaps someone in your area will see this and let you take a peek.
    I wonder if this setup would let a service reminder to be reset?
    Mod Squad
    May 2007
    Western NY
    I expect not, since that's not a typical automotive function.
    Karl
    2007 R1200ST
    Mansfield,MA
    It seems that this is progress anyway. For me, a GS911 really doesn’t make sense cost wise.......and Apple wise
    I hope to hear of continued progress
    Mod Squad
    OBD relates to engine performance and emissions. Codes for other systems are not standardized between manufacturers.
    For European Mercedes you can attach a "Mercedes-me" adapter to your OBD connector that will bluetooth to your smartphone and ...
    The Mercedes me Adapter lets you experience the dialogue with your vehicle in a totally new way. You can automatically record the routes you drove or the refueling stops you made on your smartphone, quickly and easily locate your parked vehicle and always keep an eye on current vehicle data such as odometer reading and tank fill level. At any time and conveniently with the Mercedes me Adapter app. Benefit from our individual Maintenance Management and receive suitable offers for your service appointment from your Mercedes-Benz Service partner. In the case of a breakdown or accident, prompt and effective help is provided by the appropriate checklists, direct contact with customer support and the relaying of the vehicle data as well as (depending on your smartphone settings) your current position. At the same time, you have access to a host of offers, services and information from the world of Mercedes me.
    Wait for it ...
    https://www.mercedes-benz.com/en/mer...ivity/adapter/
  1. On-Board Diagnostics 2 (OBD2)
    By robsryder in forum Wetheads
    Last Post: 12-22-2018, 10:43 AM
  2. Texa Diagnostics - GS911 competitor?
    By drneo66 in forum Motorrad
    Last Post: 03-26-2018, 01:23 PM
  3. Replies: 5
    Last Post: 02-10-2018, 07:29 AM
  4. Diagnostics of lower end R60/5
    By BimmerCrab in forum Airheads
    Last Post: 03-06-2012, 12:07 AM
  5. fan diagnostics
    By Marvhil in forum Flying Brick K-bikes
    Last Post: 01-23-2009, 08:56 PM
