Results 1 to 12 of 12
Thread: New to me 2015 RT!
    John. jstrube's Avatar
    Nov 2009
    Atwater, CA
    New to me 2015 RT!
    After owning my 2005 RT for 10 years, I figured it was time to upgrade.
    So, I found a nice used RT that was used by Eagle Rider with 60k miles for a great price, fully optioned.
    The thing is, he didn't have the 2015 manual, I think I got a 2014 manual. The display functions seem a little off from the manual, or I do not have the patience to work through it. Any place I could go to get a new 2015 manual?
    Also, this bike seems lower than my 2005, could have a low seat, I am going to get a new seat pretty soon anyway. I love the Sargent on my 05.
    I am really confused by the wonder wheel, it pivots inward and outward... A super quick rundown might help. Next up, pair my stuff, buy a NAV unit and put another 60K on this great bike!
    Only thing I need to check, and a photo would help, is to see if the windshield is going all the way down. It stops, but seems as if it should go lower.
    Also, does the NAV somehow lock into the dash so it cannot be easily stolen? My 05 at least had a funky screw bit.
    John.
    John.
    Atwater, CA
    2015 R1200RT
    Tucson, AZ, & Madison, WI
    Quote Originally Posted by jstrube View Post
    John.
    I had a 2005 RT once. Rode it all over the U.S.
    A BMW dealer should be able to get you the 2015 manual. A dealer should be able to tell you if your windshield is working right. The Nav does not lock on on the 2014 and later RTs. If you leave the bike, take it with you.
    It took me a while to get used to the wonder wheel. Now I am used to it.
    Jeff Dean
    Tucson, Arizona, and Madison, Wisconsin
    Co-founder, 1972, of BMW MOA -- http://bmwdean.com/r1200rtw.htm
    2017 R1200RT, 2019 R1250RT, 1967 R60/2
    Sep 2009
    Chestnut Hill, MA
    John - BMW Motorrad has a website from which you are able to download a PDF copy of the 2015 RT manual...and a whole lot of others besides. Anyway, take a look at this URL(http://www.bmw-motorrad.com/com/en/i...html&notrack=1). You'll have to wade through it a little, but you'll be able to eventually get the manual you want. This will do until you get a hard copy.
    I hope this is helpful.
    JG
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    Watching the sunrise outdoors statistically increases your odds of having a good day. And needing a nap after lunch.
    Wills Point, TX
    Quote Originally Posted by bmwdean View Post
    To add to BMWDEAN list:
    You'll find your manual here http://www.bmw-motorrad.com/com/en/i...html&notrack=1
    The wethead has a lower seat 31.7-32.5 inches, you may also check to see if the bike is equipped with the low seat option 29.9-30.7 inches.
    Jay
    Registered User powwow's Avatar
    Aug 2015
    Bend, OR
    John.
    The seat has a high and low adjustment. Lift the seat, turn it over and you'll see how to make the adjustment.
    Congrats on your new scoot!
    Larry Gregerson; Bend, OR
    MOA #93031
    Sep 2009
    Chestnut Hill, MA
    John - Looks like you're getting some assistance with the new bike. You should be able to DL and read the 2015 manual.
    I don't want to turn this into a windshield thread, but there are many alternatives, both OEM and aftermarket. BMW started making a "Low" windshield (part #46 63 8562239) for the bike in, I think, 2017. Oddly enough, the piece costs more than the original size. I suppose it depends on the weather you'd expect to encounter. I'd take a photo, but I replaced my OEM with a normal size V-Stream. The photo wouldn't do much to help. With the V-Stream even when it's cold (upper 30s) I leave it in the lowest position. That said, I'd still prefer more summer ventilation.
    All in all, it must be a big change from the 2005 version. Have fun!
    Debbie's Servant Lee's Avatar
    SW Iowa
    Quote Originally Posted by ExGMan View Post
    JG
    I copy the Riders Manual to my computer and phone.
    I use the PDF version more than the paper manual because the PDF has a search function.
    Lee
    2016 R1200RS
    MOA # 30878
    Mar 2011
    socal
    I really like my 15RT
    As far as windshield’s go check out Werks Quite Ride, after riding in heavy rain I switched, went from getting drenched to almost dry
    My RT buddies have all switched, Werks gets ***** from me
    Jim
    Quote Originally Posted by t6pilot View Post
    Jim
    I use the Quiet Ride windshield on my R1200RTs year 'round.
    https://www.werksparts.com/quiet-rid...eld---bmw.html
    http://bmwdean.com/1200-head.jpg
    Jeff Dean
    Nov 2009
    Atwater, CA
    You guys sure are helpful!
    I have a new iPad, so I think the .pdf manual will suite me just fine.
    Too bad they did not provide a locking solution for the NAV. I was hoping I just missed something.
    So far, the windscreen seems pretty quiet. This bike is amazing, I just need to learn that dang wheel! haha!
    John.
    Atwater, CA
    2015 R1200RT
    Registered User kevinsclo's Avatar
    Sep 2013
    Toronto, Canada
    I use the left “glove box” to store and have the GPS locked when parked.
    The central lock system should keep it protected.
    Mar 2011
    socal
    I solved the nav security issue when I bought my 15RT
    It works until you get a committed thief, then nothing works
    I removed windshield and drilled a small hole in push button near the glare shield, then screwed a stainless sheet metal screw in(button won’t move with screw in)
    Reinstalled windshield. With windshield in parked position there is no room to access screw head, i’ve Parked in some pretty crappy areas at times and nav is still there
    Again if some miscrete really wants it, no matter where it’s on bike they will get it
    Jij
  1. 2017 RT vs. 2015/16 RT
    By Sufferin_Boothead in forum Wetheads
    Last Post: 10-05-2017, 02:08 AM
  2. 7Mts Campout, 2015 version Aug 28-30 2015
    By kaldewaay in forum Regional Northeast
    Last Post: 07-18-2015, 07:01 PM
  3. Hello all, new guy here with a 2015 RT.
    By ehc0720 in forum New Members
    Last Post: 06-26-2015, 03:07 AM
  4. Replies: 0
    Last Post: 05-06-2015, 03:34 PM
  5. Replies: 0
    Last Post: 05-06-2015, 03:30 PM
