Results 1 to 15 of 18
Thread: Yearning for a sport bike...
    Registered User captainmarko's Avatar
    Apr 2015
    Las Vegas, NV
    ...and always had a soft spot on the blue and white striped k1200s, circa 2005-ish.
    And I just found one. With 47,700 miles on it.
    I'm an experienced rider, IBA member in good standing, with a paid-for 2015 R1200RT, so this isn't my first rodeo.
    My questions are, with almost 50,000 miles on it...
    1. what problems should I look for?
    2. are there any known issues that are known to crop up at this mileage?
    3. what kind of life can I expect from a 1200 with this many miles on it?
    Thanks in advance.
    Sleep in the trees and keep your knees in the breeze.
    Sep 2006
    CENTEX USA
    Had that color combo for several years Miss the adrenaline rush of roll on, but not the visits with LEO's!
    The cam chain tensioner hopefully was changed, it is located just behind right fairing and if the upgraded one is there it is a vertical tube on top of clutch housing instead of a flat plate. BMW recommends cam chain replacement at 30K(from memory) most likely for units that went that far with no tensioner. I replaced rails,sprockets, and tensioner on H's way before the "recall" as her sounded like marbles under the valve cover at start up.
    The rear wheel spider was a service bulletin to upgrade to a forged unit like the R series of same vintage
    The rear suspension also had a dog bone link that was a service bulletin
    Both can be verified with VIN check with a dealer and open ended until completed by a dealer at no cost.
    Oh, and the fuel pump plate where the QC snaps in is also on that list like all other models with that Siemens part. Cannot see that unless yank is pulled on the K's
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Is this not a Flying Brick model?
    Kevin Huddy
    Sep 2006
    CENTEX USA
    First year Wedge
    Jul 2007
    Big Sky Country
    I was not sure, but thought that fairing was on the bricks.
    Kevin Huddy
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    There's also the plastic cam chain jump guard.
    Steve do you remember, once he updates the cam chain and sprockets does he need to change them every 30,000 miles.
    I don't remember this service being needed on the K1300S which has the updated setup.
    Here's a picture of the updated tensioner.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2003
    SW Iowa
    Remove this cover to see if you have the cam chain jump guard.
    Jump guard is not in place in this picture.
    Jump guard in place in this picture.
    Lee
    2016 R1200RS
    MOA # 30878
    Sep 2006
    CENTEX USA
    Thanks Lee,
    Forgot about the guard...figure if you see the tall tensioner that the guard was done at same time, however maybe an assumption unless documented.
    I do think the original litter before they upgraded the tensioners with higher mileage were the concern with the 30K schedule .My 05 never developed the noisy valvetrain as I added the tensioner early miles wise.H's already was around 30K when we got it...and very noisy
    And my location of tensioner was a bit off, behind fairing, but definitely on cylinder block, not clutch. Haven't looked at one recently...great pics.
    Left Coast Rider
    Nov 2011
    I see this bike doesn't have the stock seat cover. Hopefully it has aftermarket padding too because the stock seat is a vinyl-covered crucifix.
    In addition to the above, one last thing to watch out for is worn clutch basket springs. Its not debillitating but the rattle can be irritating. As far as mileage is concerned, as long as the oil and all filters have been changed, the brakes (servo-assisted) have been bled regularly and the valves checked/adjusted per the maintenance schedule, this bike has tens of thousands of miles ahead of it.
    Lastly, the blue and white ones are the best/fastest/coolest. Not sure why I say that.
    Dec 2018
    Minneapolis, MN
    I just bought this one. 2015 K1300S Motorsports Edition. Around 1500 miles. Yes. 1500. HP Forged Aluminum wheels. ESA II. Quick shifter. ABS. Akropovic Exhaust. Some carbon bits. Helibars. Kaoko throttle lock. BMW Sport Panniers.
    Just purchased some Pirelli Angel GTs for it as I plan on using up the remainder of the stock Metzlers this Spring.
    Getting a little older and was looking for something sporty I could also tour on. Ride report this Spring.
    It is 9f and snowing currently.
    Apr 2015
    Las Vegas, NV
    Beautiful!!!!
    Apparently we both have the same itch.
    that is a gorgeous motorcycle
    Registered User powwow's Avatar
    Aug 2015
    Bend, OR
    Wow, that is one striking motorcycle...nice purchase.
    Larry Gregerson; Bend, OR
    MOA #93031
    Registered User radiofun1's Avatar
    Dec 2009
    Helena, Montana
    Abs
    Keep in mind that the 2005 bikes have ABSIII, also know as I-ABS. The ABS modulator and/or the servo motors are known to fail more frequently than other designs and, more importantly, the ABSIII modulators are not repairable. If you do have a failure the only options are buying a new ABSIII modulator ($2300 or close to that) or performing an ABSektomy and turning the bike into a non-ABS unit.
    Left Coast Rider
    Nov 2011
    Quote Originally Posted by radiofun1 View Post
    Keep in mind that the 2005 bikes have ABSIII, also know as I-ABS. The ABS modulator and/or the servo motors are known to fail more frequently than other designs and,.....
    ....typically attributable to disintegrating brake hoses and lack of regular fluid flushing. If the bike has had its scheduled maintenance checks, it is highly likely that the ABS/Servo unit is just fine. Further, this bike came equipped with braided steel lines and did not suffer the same fate as many neglected rubber-hosed R1100/1150.
  1. Woman's Sport Bike Rally in Big Bear CA May 29-31
    By REDC650GT in forum Women of the MOA
    Last Post: 03-20-2015, 10:12 PM
  2. Bike Sport Pics
    By Threeteas in forum Photography
    Last Post: 04-27-2008, 09:25 PM
  3. Cruiser vs. Sport Bike
    By p_interceptor in forum Oilheads
    Last Post: 05-10-2005, 01:59 AM
  4. get title to my sport bike?
    By ranceg2 in forum Campfire
    Last Post: 01-22-2004, 05:26 PM
