Results 1 to 5 of 5
Thread: Camhead feeler guages?
    Registered User lvermiere's Avatar
    Jan 2004
    Grand Forks B.C.
    2011 1200RT.
    I've checked my valves every 10k miles and now at 65k miles.
    3 different feeler gauges. None worked as well as I would have liked. Too short.
    What do others recommend?
    Lester V in B.C.
    #36473
    Aug 2018
    Fargo, ND
    I haven't checked the valves on my RT so not sure what the problem is, but you can take the feeler gauge set apart and just use the feelers out of it. Years back I had two sizes I used daily. I bought a couple individual feelers from Snap-On and connected them with a short cord. That was thirty years ago, they are still in my tool box.
    Snap-On has the "normal" length feelers, plus 12" long ones too.
    Registered User jandhumphreyme's Avatar
    Sep 2013
    Central Maine
    My gauges are standard length, 4" maybe. I remove them from the holder, seems to work slick, what length gauge are you using?
    So often times it happens that we live our lives in chains
    And we never even know we have the key
    i should be out riding! wyman.winn's Avatar
    Jul 2013
    Solvang, CA
    Hmmm....i really don't see a problem here....
    i use a Starrett NIST certified feeler gauge set that have the leaf length of 2.75".....used successfully on my 13RT....and i did not remove them from the set...
    i do use a pair of loose gauges from Beemer Boneyard for the adjustable type tappets though....
    btw, i check my valve every 6000 miles and the bike has over 104000 miles....do the math...
    Merry Christmas!
    ~wyman~
    2015 BMW S1000R - Duke - Black Storm Metallic
    2013 BMW R1200RT - Sassy - Fluid Grey Metallic
    Jan 2004
    Grand Forks B.C.
    Quote Originally Posted by jandhumphreyme View Post
    My sets are 2.5 and 3 inches long. They have worked Ok for all the valve checks/adjusts I've done since 1973. No real problem.
    In my original post I was just wondering what others were using that were longer. I've just ordered an 8 inch set in metric.
  1. Go-No-Go Valve adjustment feeler guages Oilhead
    By will3hawks in forum Oilheads
    Last Post: 10-15-2016, 03:28 AM
  2. K75S Guages
    By 67972 in forum Flying Brick K-bikes
    Last Post: 05-31-2009, 03:30 PM
  3. guages
    By bmdubyou in forum Airheads
    Last Post: 10-17-2005, 06:16 PM
  4. vacuum guages
    By 12960 in forum Airheads
    Last Post: 08-03-2005, 08:08 PM
  5. .15mm and .30mm Feeler Guages/Twinmax
    By stoon48 in forum Oilheads
    Last Post: 12-30-2004, 10:22 AM
