happy wanderer
Day Dreaming ...
Need to see the spreadsheet.
Happy New Year DY! I see your sense of humour is intact; that's good.
So I think by now Roger is probably a bit tired of answering the same questions about fueling and batteries but at personal risk I will attempt to fill in a blank here that is being missed.
The spec sheet for the Odyssey states that the battery must be charged to 14.7 volts to have a full charge. It also states that anything other than a full charge will lead to sulfation and lower performance. Most standard battery chargers don't charge to 14.7 and actually very few do that AND have the higher charge rate they specify. This is why they have a list of approved chargers.
I should also note that some riders here like GSAddict for example have modified their alternators with a 14.7 volt regulator in order to run Odyssey batteries worry free and to get the max life and performance out of the expensive but very well made and long lasting Odyssey PC680. I use them also in my 1100RT and my R80G/S. For the R80 I bought a digital adjustable regulator because they are cheap and easy to install and dial up the voltage. For the RT I just use my charger for an hour when I get home which tops it up to 14.7 and this seems to work well as the battery is 8 years old now with zero issues.
I guess the short answer is not all AGM batteries are the same despite the similar chemistry. Having worked with the US Military and their rechargeable battery needs I am quite sure they are using Odyssey for very good reasons.
