Results 1 to 4 of 4
Thread: How to remove top box mounting plate '94 K75S
    Hopefully this is an easy one. I have a Ď94 K75S with the factory top box. I know how to get the top box off the rack but I canít get the plate that it connects to apart from the rack. Is there a trick to it that I am missing?
    Jun 2009
    Rochester, MN
    They are simply friction fit.
    Taken from a similar thread: "IIRC - it is supposed to be slid under the forward edge of the rack while being pressed down (so the foam under it compresses) and then the bottom edge locks into the rack."
    Current: 2007 BMW R1200RT
    Thanks, I'll give it a shot. I knew there was an answer here somewhere but I couldn't find the thread...
    Liaison 20774's Avatar
    Turns out the answer that was quoted comes from one the threads in the Similar Threads pane at the bottom of the screen:
    https://forums.bmwmoa.org/showthread...Mounting-plate
  1. Advice on how to remove timing plate on K100
    By wasfast in forum Flying Brick K-bikes
    Last Post: 03-18-2015, 08:46 PM
  2. K75 Mounting plate
    By bchurch in forum Flying Brick K-bikes
    Last Post: 05-22-2010, 09:11 AM
