Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: YouTube 12000Mile/20000Km RTW Service Video Series
  1. #16
    drive shaft splines
    what is the scheduled amount of miles between drive shaft spline lubes.In the video i noticed he didn't do the front splines.Do they ever need to be lubed?
  2. #17
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    Quote Originally Posted by jimbem View Post
    The spline lube is not called out for service by BMW on ANY LC motors. It is from past years where this comes from where the splins were not robust enough and without lube would wear out pretty quickly.
    JVB and others before him have shown and incorporated it into maintenance from experience.
    It is particularly important to GS/GSA who do water crossings and such. Seems the boot is a curse in that it helps hold moisture.
    You can do the top but beware it is even more of a pain as it has a cir clip that must be snapped into place. If you look here:
    https://advrider.com/f/threads/r1200...orial.1129815/ you will find 40 some pages of spline lube experience including mine.
    I have done the lower at 6K and at 24K I will remove the drive shaft and do the top.
    The tip of using a flexible wire works very nice to get the lower into place.
    Lee
    2017.5 R 1200 GSW
  3. #18
    AZ
    I have never used a wire to get the drive shaft aligned. I just use my fingers. The wire method does seem to work well! For the boot seal, I just use marine grease rather than the very expensive BMW spec'd stuff. Yeah, it doesn't look as sexy, but it is made to work in wet situations and should keep most water out.
    I would add a note to the video content. Bolts that have locking compound applied will remove a lot easier if you apply some heat. Once removed you either need to replace the bolt or clean it with a wire brush and then reapply locking compound. The engineers specified locking compound for a reason!
    MOA #107139
    RA #28511
  4. #19
    Quote Originally Posted by azgman View Post
    The use of the wire is just another technique, I'm glad your method works.
    I too am currently using a waterproof grease very common with off road motorcycles on my own accordion boot seals...I think it will work well and lots less expensive than what's specified there. I'm looking forward to the end of next season time frame service to see how each one handles water intrusion.
    You are right about adding heat to loosen up locking compound on threads that are not close to other things like rubber or wires...some need over 300deg F, so I really would be careful around the brake pin sleeve boots and such. As you are well aware, BMW refers to bolts that are "one time use" as micro-encapsulated. I had a good discussion with an engineer that works for Nylok over Christmas, and they supply what could be used on our bolts to hold on the rotors, Paralever arm bolts, etc.
    https://nylok.com/precote-85-better-...nsion-adhesive
    You are also correct that bolts that call for thread locker should be cleaned prior to adding additional adhesive it not being replaced, thanks for pointing that out.
  5. #20
    AZ
    Good point about the use of heat on the brake caliper bolts... that would be no bueno!
    MOA #107139
    RA #28511
  6. #21
    Jun 2006
    Kamloops, BC
    Valve Shim Kits
    BoxFlyer, would you please tell us which Valve Shim kit you use or recommend and what the correct diameter of the shims would be.
    By the way, I found your videos very well done and an excellent learning tool for the Waterboxer. Thank you very much !!!!!
    Ron
  7. #22
    Hi Ron,
    Here’s the link to the 8.90mm diameter shim kit.
    https://tinyurl.com/y6vep5ll
    There are links to every tool I used in the videos in the description of the Part 1 video, other forms and worksheets as well.
    Glad you liked them and hope it helps.
  8. #23
    Old Rider - OK Mechanic 105258's Avatar
    Mar 2004
    Teulon Manitoba Canada
    Netric Shims
    Great video's Thank you. I'm curious as to where you got your metric shims ?Can you let me know. Thanks
    David Nicholls
    Teulon Manitoba - Canada
    2015 R1200GSA-LC
  9. #24
    The link in post #22, above is still the correct link.
  1. Working with Cables - YouTube Video
    By ExGMan in forum Motorrad
    Last Post: 05-10-2016, 02:09 AM
  2. Replies: 113
    Last Post: 11-12-2013, 11:50 PM
  3. S1000RR - Best YouTube Video Ever
    By gw in forum S1000 - The Hothead
    Last Post: 04-01-2011, 11:33 AM
  4. A Youtube Video on 8v K-Bike Spline Failures
    By ted in forum Flying Brick K-bikes
    Last Post: 02-05-2010, 03:46 PM
  5. RT Safety Lights youtube video
    By texanrt in forum Campfire
    Last Post: 10-07-2009, 12:23 AM
