Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: 2003 K1200GT - What glue to repair tabs?
  1. #16
    Oct 2017
    Draper, UT
    Similar problem but I don't have the pieces - can I manufacture bracket from PBT + PC
    I have a similar problem in that two brackets on the inside of the upper fairing (one at top where it connects to the inner fairing, one on the other side where the upper fair connects to the frame).
    Was considering fashioning a similar bracket from steel and attaching with 2-part epoxy, but wondering if it would be better or even possible with a plastic resin? If I fashion a block and then dremel it to shape?
    Quote Originally Posted by myK1200rs View Post
    For all plastics on Car or Motorcycle made in Germany, the type of plastic it is made of, is identified in abbreviated text on the inside of each part. In the case of all K1200 and also Boxers of the same era (1996-2005), the inside fairing parts identification says "PBT + PC". Always look for the letters between > < (see attached photo).
    It is not ABS. Plain ABS has poor low temperature characteristics.... it is too brittle when cold.
    if you want to get a bit more technical with details to research the perfect fix, a quote about this from one expert on another "K series" forum:
    "PBT + PC alloy is a mixture of Polybutylene Terephthalate and Polycarbonate resins. "
    "This stuff has excellent low temperature strength. It has nothing to do with ABS (Acrylonitrile-Butadiene-Styrene). It also cannot be glued using ABS glue, or heat-formed in the same way ABS can."
    "Xenoy is a trademark for GE's line of PBT-ABS resins. Makroblend is Bayer's trademark for their SIMILAR family of PBT-PC and PET-PC resins. (PET is Polyethylene Terephthalate). PBT and PET have similar characteristics."
    Attachment 71861
  2. #17
    Pantana-The Lonesome Weir
    Aug 2003
    Hampden, MA
    I've worked at a Plastics Fabricator for 36 years and own a 03'GT. I've had spills where the side cases looked like broken eggshells, and had the same and more broken tabs up at the front fairing parts. Best adhesive for this material is Methyl Methacrylate. Now made by several companies - Plexus, Locktite are a couple. True wonder adhesive for many kinds of plastics. It heats up when mixed, and bites into the materials. It even works on some of the "waxy" poly plastics.
    Pantana
    The Lonesome Weirdos
  3. #18
    '14 R1200 GS Adv bigjohnsd's Avatar
    Oct 2018
    Black Hills, SD
    Looks like some healthy stuff, NOT
    Methyl Methacrylate and your Nail Salon
    NIOSH Pocket Guide to Chemical Hazards
    But Grainger sells it in 500ml quantities for $36
    Loctite H3000 also available by the single tube on Amazon LOCTITE AA H8300 Structural Adhesive - 50 ML Dual Cartridge - B/A - 83001 IDH:398426
    by Loctite
    Last edited by bigjohnsd; 05-28-2020 at 10:48 PM. Reason: added Loctite H3000 link
    The only dumb question is the unasked question - Anonymous
    Eat every Ham Sandwich like it is your last Ham Sandwich! - Anonymous
  4. #19
    Mansfield,MA
    Quote Originally Posted by johncolleton View Post
    Good to see you on Pantana
    Mod Squad
    2009 F800GS 1994 TW200
  5. #20
    Anybody have any idea how many Superfund Sites there are because of former plastics factories?
  6. #21
    Liaison 20774's Avatar
    Let's keep things on topic, please! The OP wanted help with choosing a glue.
  7. #22
    OK, but the fact that the proper glue is highly hazardous might actually add some value to the conversations. Or not, depending on if I use it or you use it.
  8. #23
    You should get all the info you need on the product packaging regarding hazards.
  9. #24
    Oct 2018
    Black Hills, SD
    Loctite H3000 for the win
  10. #25
    Registered User WalterK75's Avatar
    Feb 2009
    Mississauga, Ontario
    Here's a blurb I found about a product that may be of use to some of you.
    Plast-aid
    https://www.plast-aid.com
    Plast-aid is a multipurpose repair plastic used for countless applications. Plast-aid chemically fuses to some plastics like PVC ABS & acrylic and mechanically bonds to rough surfaces like wood, concrete, brick. It has a unique curing process that lets you cast glue fill form & becomes a hard plastic in 15 minutes.
    Walter
    "Every decent man is ashamed of the government he lives under."
    H. L. Mencken
  11. #26
    Quote Originally Posted by bigjohnsd View Post
    $85 on amazon !
  1. 2003 K1200GT ABS failure
    By ande2078 in forum Flying Brick K-bikes
    Last Post: 06-09-2015, 12:46 AM
  2. 2003 k1200GT Repair Manual
    By hans.arnesen in forum Flying Brick K-bikes
    Last Post: 06-28-2012, 11:31 PM
  3. 2003 k1200gt
    By akbeemer in forum Flying Brick K-bikes
    Last Post: 05-08-2010, 12:07 PM
  4. K1200gt 2003
    By gmr1200gsa in forum Flying Brick K-bikes
    Last Post: 08-25-2004, 06:28 PM
