2003 K1200GT - What glue to repair tabs?
Let's keep things on topic, please! The OP wanted help with choosing a glue.
:lurk
OK, but the fact that the proper glue is highly hazardous might actually add some value to the conversations. Or not, depending on if I use it or you use it.
Here's a blurb I found about a product that may be of use to some of you.
Plast-aid
https://www.plast-aid.com
Plast-aid is a multipurpose repair plastic used for countless applications. Plast-aid chemically fuses to some plastics like PVC ABS & acrylic and mechanically bonds to rough surfaces like wood, concrete, brick. It has a unique curing process that lets you cast glue fill form & becomes a hard plastic in 15 minutes.
