Results 1 to 4 of 4
Thread: Right Turning Tendency
    After digging a bit deeper into the turning tendency of a small percentage of K16's I thought it's time to look here.
    I am the 2nd owner of a 2012 K16GTL with 18,000 miles. I've added an additional 5,000 miles over the last twelve months and have found that the bike has a fairly aggressive right turning tendency. Aggressive may be described as not being able to take hands of the bars at any speed without the bars turning right and the bike falling left, loud front tire noise while cruising down the freeway, and tire tread abnormally wearing to the left of center line. Elaborating on 'falling left', at 65MPH I can just about take both butt cheeks off the right side of the seat and it'll ride straight (I weigh 160 LBS).
    While diagnosing this issue, I discovered that the right edge of the front tire is about 1/4" - 1/2" closer to the inside of the fork than the left side, and swapping the axle spacers does not seem to change this. One report found suggested turning the axle 180 degrees, but this did not have any effect. It's almost like the jig that drilled the axle holes through the fork at the factory was off and the axle is not true in relation to the fork. With this thought, I'm considering buying another lower fork to swap out.
    Any and all thoughts are welcome.
    Rick
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    I have a 2012 GT and have never experienced this.
    But then again, I have never had a reason to remove my hands from the bars.
    However, that said, it would appear to me that someone may have smacked up the front end.
    Joe
    “Fate whispers to the warrior, 'You can not withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    Quote Originally Posted by 61996 View Post
    Joe
    To have a quarter every time someone has said, "...I have never had a reason to remove my hands from the bars". lol
    Yes, the previous owner might have caused this damage...but nothing else indicates as such, and I know the previous owner.
    Registered User d martin's Avatar
    Dec 2007
    "The Gas City" SE Alberta
    Left Pull
    There are many threads on K1600 Forum where you can search and read
    https://www.k1600forum.com/forum/bmw...left-pull.html
  1. Starter keeps turning
    By stepvan7 in forum Flying Brick K-bikes
    Last Post: 01-15-2017, 11:54 PM
  2. Turning 40
    By MTHelmet in forum Campfire
    Last Post: 01-13-2011, 01:35 AM
  3. Turning off a 1200GS
    By bobmorse in forum Hexheads/Camheads
    Last Post: 11-09-2010, 01:15 AM
  4. I'm turning 52, turning 52 the good way
    By redclfco in forum Campfire
    Last Post: 06-27-2009, 11:49 PM
  5. Turning off electrics??
    By terham in forum Gear
    Last Post: 12-31-2006, 04:22 PM
