Results 1 to 11 of 11
Thread: Front fairing removal R1100RT
    May 2016
    St Lazare, Quebec, Canada
    Any tips on how to access the internal (by the headlight) mounting screws so I can remove the front fairing on my RT?
    The PDF manual that I have indicates to remove the instrument cluster first, but then in another section, it say to remove the fairing so that you can remove the instrument cluster .....? In either case, I cannot seem to access the mounting bolts inside the fairing. Thx
    May 2016
    May have figured out my error. Looks like the entire windscreen assembly has to be removed. Not just the screen itself. So that should allow access to the front screws.
    Registered User AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    It sure what screws you mean. You remove the windshield trim so you can lif the fairing off the windshield arms, but the headlight stays in the fairing the whole time. You unplug it and a few other things but the fairing is ultimately held on with four bolts.
    Anton Largiader 72724
    Tech articles - YouTube
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
    Mar 2013
    Winnipeg, MB, Canada
    Always the voice of reasonable reason Anton.
    You still need 24" extensions with a 10mm flex socket and the hands of a little girl.
    1997 R1100RT, 1981 KZ 440 LTD, R80RT, R90/6 sidecar, K1100RS,1983 K100RS (Cafe now)
    ďThe major civilizing force in the world is not religion, it is sex.Ē
    Jul 2004
    Charlottesville, VA
    Quote Originally Posted by dieselyoda View Post
    For what?
    For what?
    Sarcasm
    May 2016
    Windscreen was removed and instrument trim, then all (x 6) screws were removed from the fairing. But the fairing would definitely not release and appeared to be anchored at the headlight assembly. Iím currently away at work and wonít get back to this project for a few days but was thinking: is the headlight plug connection another mounting point / ie: does it provide any tension on the headlight mounting bracket and could this be the issue?
    Thx for the tips. Iíve never torn one of these bikes apart before and I donít want to break anything on a 20 year old bike.
    Mar 2013
    Sarcasm
    I actually didn't mean it to be sarcasm, or maybe I did?
    Size XXL hands and patience hasn't been working for me.
    Jul 2004
    Charlottesville, VA
    There are two threaded alignment studs near the headlight but they are not supposed to have nuts on them. Itís really easy to look at them and think they should, though, so someone may have done so.
    From memory, you get the dash off, windshield off, mirrors and side fairings off, radio antenna ground strap if present, and then you have four bolts (two at the mirrors, two where the side fairing tabs engage) and that is all. You pull the fairing (with headlight) forward and then unplug the headlight and parking bulb if you havenít already.
    I think thatís all for the 1100.
    May 2016
    Thanks. Will take another look when I get home. Difficulties with this may be related to method PO used to install the Xenon headlight and power supply. Incidentally this is the original reason why I’m removing the fairing. Restoring the bike to stock as it had a lot of poorly executed electrical installations.
    May 2016
    Successful.
    Turns out there's a factory installed 90 degree tab, mounted on lower left side of frame, left of the inner headlight assembly, with a nylock nut to fix the fairing to the frame. Saw no mention of this in any of my resources. Couldn't see it because of the nest of wiring from the power pack for the xenon headlight.
  1. Replies: 5
    Last Post: 05-28-2018, 11:50 PM
  2. 96 R1100RT fairing removal
    By woody99 in forum Oilheads
    Last Post: 06-01-2014, 07:23 PM
  3. Replies: 2
    Last Post: 05-19-2014, 11:07 PM
  4. 2000 R1100RT Front wheel removal
    By kpflyingv in forum Oilheads
    Last Post: 04-22-2013, 10:22 PM
  5. dual front brakes,- Fairing removal
    By florabunda in forum Airheads
    Last Post: 08-14-2008, 02:34 AM
