Results 1 to 8 of 8
Thread: rt's usb outlet stopped working
    Coming home,on the interstate my phone went dead causing me to lose my music and ability for Sarah to know i was ok in the rain.I thought it was probably the charging cord had broken where it exited the glove box under the cover. I checked that cord and another in the house and both seem to work. So it seems my usb charging port has stopped working.Is there some way to check it? Has anyone else had trouble with theirs? Any help is appreciated
    Mansfield,MA
    Try it today
    The computer may have decided that you have had enough
    Personally, not a fan of computer controlled outlets. An outlet fused direct to that battery is better for me.
    Let us know what you find.
    Mod Squad
    2009 F800GS 1994 TW200
    Wills Point, TX
    I'd connect a jump drive directly to the USB port and see if it fires up
    Jay
    AZ
    Two thoughts;
    • As mentioned the CANBUS module may have shut down the port
    • The connector on the back of the bike's USB port has become disconnected
    MOA #107139
    RA #28511
    Registered User alegerlotz's Avatar
    Mar 2015
    Greater Los Angeles
    Quote Originally Posted by jimbem View Post
    Sometimes (rarely) my RT will decide that I have no USB connected. If I shut off the bike, disconnect and reconnect the USB drive, and then restart the bike, it has always recognized the USB being there again. In fact, in most cases it remembers what song I was on when it last recognized that the USB was connected.
    2016 R1200RT
    2007 KTM 450 XC-W (10/17 - 5/18)
    2005 R1200RT (2/2015 - 12/2016)
    1985 Yamaha XJ 700 Maxim (7/1989 - 9/1991)
    thankyou ,i will give these a try and report back
    sorry it took so long to get back .I am embarrassed to say i found the problem.I plugged something else into the port and it didn't work either. So I took the right side fairing panel off and immediately saw that the wire going to the usb outlet was disconnected .While i was on the road during October I had a dealer change my air filter and anti-freeze.Apparently the tech didn't push the plug connection in all the way. A little bit of defense for the tech.I had a real hard time pushing the connection together to the point where the lock clicked. Thanks to those who took the time to respond to my post
    Mansfield,MA
    Always great to have an ending to a thread.
    Mod Squad
  1. Both Odometers have Stopped Working
    By m_stock10506 in forum Airheads
    Last Post: 05-31-2018, 03:11 AM
  2. odometer stopped working on 88 K75S
    By robsryder in forum Flying Brick K-bikes
    Last Post: 11-05-2015, 03:14 AM
  3. Heated grips stopped working
    By kewlmoose in forum Oilheads
    Last Post: 07-06-2008, 10:41 AM
  4. Speedometer stopped working
    By cb75076 in forum Oilheads
    Last Post: 05-15-2008, 01:36 PM
  5. Oil Light stopped working
    By BernieEcht in forum Oilheads
    Last Post: 02-11-2006, 04:34 AM
