Results 1 to 11 of 11
Thread: Oil sight glass leaking
    I have a 2009 R1200GS and the oil is leaking from the seal around the oil sight glass. Anyone have suggestions on how to safely remove the sight glass? I have removed the retaining clip and the clear plastic portion. I am worried about damaging the area around the seal while prying it out. Any thoughts would be most appreciated. I sent a previous thread about the final drive lubrication and got some very helpful hints. I really appreciate the help. Wonderful forum!
    Liaison 20774's Avatar
    Although not for the R1200GS, there are a number of threads in the Similar Threads pane at the bottom of the screen. I also used the Tag Cloud to search for "sight glass" and ran across this one for Hex/Camheads:
    https://forums.bmwmoa.org/showthread...ss-replacement
    Others may have specific recommendations but the above provides some things to read and ponder!
    Quote Originally Posted by ncbmw View Post
    I will be following your progress on this, as my 2008 RT Oil Glass is so dirty that is essentially useless. I read the links provided by others and they do not give me a warm fuzzy feeling that this is something I want to mess with. I am also confused... is it plastic or glass ? Or are there two pieces involved - one glass one plastic ?
    I wonder how much the dealer would charge to put a new one in there. I change my oil quite often just so I know that the level should never get too low, but I would really like to be able to use the glass for its intended purpose.
    Belton Tx
    My K75 uses the same plastic sight "glass". I burned a hole with a soldering iron and put a large sheet metal screw in the hole and used vice grips to pull sightglass out. This way there is no chance of damaging case by prying.
    Ron
    91 K75RT ABS
    13278
    Near Lynchburg, VA
    I’m not familiar w/ your model,but if it is the same as a K75:
    When you change your oil next time.
    roncooper
    Exactly!
    Then clean out the seal area and find a socket to use as a drift to tap the new sight glass in. Nothing larger than the OD of the seal and only touching the exterior of the seal face, so as to not damage the metal on the engine block nor the “glass” face. Tap evenly till it seats to the bottom. I didn’t use a lubricant on the seal.
    Could be the easiest repair you’ll ever do on your bike.
    All of this should be confirmed by folks that have actually done this to a 2009 +- 1200 GS.
    Charlie
    Aug 2006
    Scranton, Pa.
    Changed out the sight glass on a couple of 1100s
    A screwdriver into the sight glass and then just rock it out. then clean the rubber grommet and gently press the new sight glass with a socket by GENITALLY tapping into the space. Gentle is the critical word here, though I would replace the rubber grommet while I was at it.
    That having been said, there are other members who are far more skilled than I and I would heed their counsel.
    BTW, Sight glasses often get smokey if one changes from regular motor oil to synthetic.
    Best,
    3hawks
    CENTEX USA
    Sounds like that might hurt
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    ...'specially if the motor is hot and you hit a pipe.
    13278
    Near Lynchburg, VA
    To remove old Sight Glass on K75’s:
    Heat a piece of wire (16 ga) with a torch, of some sort, to “red hot” and burn a hole off center, toward, but not on the edge of the “glass” (plastic). Screw a coarse thread like a Sheetrock screw in and pull one side out. If it’s leaking, it is already lubricated and takes hardly any effort to remove.
    Can someone confirm this would work on a 2009 R1200 GS.
    Charlie
    Registered User k12lts's Avatar
    Indiana
    Should work fine, the part number for the sight glass is the same for both bikes. 11 11 8 523 906
    2010 R1200RT, 2011 Ural Patrol, 1981 R100, 1975 R90S
    BMW MOA 37304
    Apr 2007
    Nacogdoches, TX
    Unless I missed mention of it, one should note that there is a circlip that keeps the sight glass thingy from popping out on its own.
    I believe it's applicable to all R1200 models except some early '05s
    '08 BMW R1200RT
  1. sight glass '98 RT
    By bp@sr9 in forum Oilheads
    Last Post: 04-01-2018, 06:55 PM
  2. Leaking oil level sight glass 1985 K100RS
    By 64372 in forum Flying Brick K-bikes
    Last Post: 06-21-2016, 03:28 PM
  3. Sight Glass Leaking in 2008 R1200RT
    By rps58 in forum Hexheads/Camheads
    Last Post: 04-24-2014, 08:31 PM
  4. oil sight glass
    By rado360 in forum Oilheads
    Last Post: 09-29-2008, 11:17 PM
  5. More sight glass
    By TIGINBNA in forum Oilheads
    Last Post: 02-24-2007, 04:40 PM
