Results 1 to 2 of 2
Thread: '94 K75 Exhaust Sleeve
    Happy Thanksgiving everyone!
    I spent $5.50 on a sheet of copper to make a sleeve between the header and the muffler. I tried using copper gasket goo. It didn't hold up. After some adjusting the copper to size, I went for a test run today. No more popping.
    I have added connectors to run my Gerbings gear. On today's test run I plugged in the controller for the under jacket. It worked fine. I also ran the K with the running lights and the heated grips too. The whole system is doing alright.
    Cheers,
    Bill
    Good job.
    For those that have access to a dealer, the factory exhaust gasket is : 18 12 1 457 142 GASKET $14.25
    Early Kbikes are blessed with a very robust charging system. They will easily handle whatever you throw at them, especially the later ones with the 50 amp alternator (black plastic rear cover).
  1. Oil in the exhaust
    By kskraye in forum Hexheads/Camheads
    Last Post: 06-27-2016, 07:03 PM
  2. Shock sleeve covers
    By creteman in forum Hexheads/Camheads
    Last Post: 05-16-2013, 01:38 PM
  3. airhead cylinder sleeve replacement
    By TOMDURRANT in forum Airheads
    Last Post: 05-14-2013, 04:20 PM
  4. Sleeve in the right side Hand grip
    By wzellwzell@yahoo.com in forum Oilheads
    Last Post: 11-21-2010, 02:42 PM
  5. 2 into 1 exhaust
    By yaktackler in forum Airheads
    Last Post: 10-27-2010, 11:41 AM
