Results 1 to 11 of 11
Thread: Anyone near Bloomington,IL that could go over my bike with me?
    So I bought my bike back in December of 2017. It is a 1977 BMW R75/7. I spent that winter getting it running and then rode it for most of this season. With the cold weather upon us again I would like to start tearing it apart and really get it in tip top shape. I'd like someone with some experience with these bikes take it for a ride and give me some second opinions on what I think it needs.
    Thanks!
    Hobie7
    Liaison 20774's Avatar
    Welcome to the forum! While you wait for some locals to check in, maybe you can tell us what you did to get it running and how it has been running? What kind of gas mileage does it get? How many miles are on the clock? I'm sure there are some short term maintenance things that should be done, and you might be looking at bigger items depending on the mileage and past usage.
    Sep 2006
    CENTEX USA
    Welcome to the forum Hobie7
    If the screen name is wrong, call the office and they can correct.
    That said, some response may come along here, more so in Airheads.
    One of the suggestions will be to check this site out, join and find folks near you.
    http://www.airheads.org/
    Good luck with the /7
    Ya if I can't find anybody local I may just start asking questions in here and airheads.org.
    Photo Gallery
    I'll try to make this short and sweet.
    The bike reads 90,000 miles but it could be 190K I suppose.
    Bought the bike from a guy that never got it running. The question that should have caught my attention more was "Are you good with electrical?". At some point the bike had a fairing and hard bags on it. There were a lot of vampire crimps and splices. The biggest problem was there was no fuses! With some work I got the electrical sorted out and started getting it to at least turn over. At that point I was willing to put more effort into it. Honestly once it's warmed up she runs pretty darn well.
    List of fixes:
    Removed vampire crimps
    Installed fuses
    Installed new battery
    Rewired ignition/tumbler
    Replaced headlight relay
    Replaced choke cables
    Rebuilt petcocks
    Adjusted valve clearance
    Replaced tires
    Replaced stripped valve cover bolt
    Rgapped spark plugs
    Cleaned carb jets
    Replaced clutch safety switch
    Replaced brake pressure sensor
    Issues:
    Currently it leaks oil so I bought a complete gasket kit.
    The clutch seems at the high end of the travel so I'm thinking it needs to be replaced.
    The brakes seem a bit soft so I'm thinking I need to rebuild the master cylinder and/or replace pads
    Even with a new battery it seems to have a hard time getting that first crank, not sure if that is a starter or alternator issue yet
    And if I don't find a local person I'll prolly just copy\pasta all of this into the airheads section.
    Airmarshal-IL James.A's Avatar
    Sep 2013
    central Illinois
    I live near Peoria. Send a PM for telephone contact. There is a member near Lexington who has an Airhead tech day scheduled for May 5. Are you a member of the Airheads Beemer Club? www.airheads.org
    I think 750's are the very best airhead motor.
    "hard time getting that first crank", could be a static timing issue.
    1973 R75/5
    Quote Originally Posted by hoobie7 View Post
    Nice list of things that you did! Install fuses? Those are normally in the headlight shell...did the PO wire directly across the contacts or was their a different headlight bucket installed?
    As for the first crank...are you saying that the starter turns over very slow or are you saying it cranks fine but just doesn't fire up quickly? If it's the later, it could be timing, but could be the carb enrichener circuits aren't working, could be the valves are not set quite. Not sure of your experience with the Airhead motor, but there are a few "quirks" about setting the valves.
    As for the front brake, you probably should at least flush the fluid and see where you are...then think about a master cylinder rebuild.
    Where are the leaks? Two common places are the pushrod tube seals and the oil pressure sender switch. At 90K, the pushrod tube seals are likely hard and they need to be replaced.
    The Big Red One sgtbill's Avatar
    Jul 2006
    Columbus, IN
    The Hoosier Beemers is your local club. Check out this club. You are also within striking distance to one of the top Airhead technicians in the country. Gunther Wuest in southern Indiana is well known for his knowledge of /2, /5 and other Airhead motorcycles.
    sgtbill
    Duty First!
    86 K100RS EML & 79 R100S
    2007 F800ST & 2014 F800GS & 2014 F700GS
    Quote Originally Posted by sgtbill View Post
    I think the Dinky Dozen would be more local to Bloomington, IL. Send a private message to Chasman and I suspect he can aim you in the right direction.
    The guy I bought it from had already removed the fairing but my guess is it had some sort of remote fuse holder because where the fuses should have been there were just wires soldered on to the tabs.
    Ok, got signed up on the Airheads forum and found the central Illinois tech day. Also found the Dinky Dozen on Facebook. I got in contact
    with James.A so hopefully I'll get this bike all sorted out. Thanks everyone for the help!
    Sep 2013
    central Illinois
    So... I met up with Hoobie today to give his airhead a good looking over. Without knowing the history of the bike, he has a very fine specimen. I think it is an honest 90,000 mile bike that has seen more care than neglect in the last 40 years. A diamond in the rough, if you will.
    1973 R75/5
    Local to you
    I am a Champaign, IL rider.
    I would enjoy looking at your bike with you sometime
    and perhaps I could help.
    However the guy in Indiana would be a good day trip
    if you'd like to head over there one day this winter.
    He understands the vintage bikes.
    Linton, Indiana is his area.
    I have been wanting to pay him a visit.
    PM me.
    or email
    ken@shape-master.com
  1. Replies: 3
    Last Post: 02-26-2017, 01:30 PM
  2. Replies: 5
    Last Post: 12-22-2015, 01:01 PM
  3. 2012 GTL - Bike to Bike Comm, Retaining Bluetooth ?
    By ericmsimon in forum Straight 6 K1600 GT/GTL/B
    Last Post: 11-25-2012, 04:37 PM
  4. BMW F650GS as a touring bike and starter bike
    By jnslatky in forum F-Twins
    Last Post: 02-01-2012, 01:45 AM
  5. Bloomington/Normal IL
    By nardowell in forum New Members
    Last Post: 03-16-2010, 03:42 AM
