Results 1 to 4 of 4
Thread: ‘04 1150 RT-P Fog Light Help
    Registered User jcabiles's Avatar
    Nov 2013
    Vienna, VA
    My left Fog Light is out on my RT-P and need to get access to it to change it.
    I can’t access the plug or connectors so I know I need to take off the body panels. It appears I also need to remove the front fairing to access the area of the fog light connections. The question is what’s the sequence/process to get to the fog light.
    fog lights
    Quote Originally Posted by jcabiles View Post
    They're easily accessed just by removing the panels. In your case, just remove the left panel and it's right there.
    RPGR90s
    Nov 2013
    Vienna, VA
    Quote Originally Posted by RPGR90s View Post
    RPGR90s
    That may work for a regular RT, but on an RT-P, you still can’t get access to the light.
    Nov 2013
    Vienna, VA
    Finally got to it.
    There was a speaker housing that was blocking access to the fog light, and of course the mounting bolts were hidden.
    Removed the wind screen and also the dash panel. Once those were removed there were three bolts holding the speaker housing. Once that was removed I could get my hands up into the round rubber cover and finally the clips that held the light bulb.
    Light bulb is on order.
    And I’m leaving out the speaker housing since it isn’t hooked up to any police radio gear, and if I have to gain access to the fog light I just need to remove the side panels.
  1. Replies: 14
    Last Post: 06-09-2017, 06:39 PM
  2. hid light bulb '04 1150 GSA
    By logbevzeke in forum Oilheads
    Last Post: 06-01-2012, 02:12 AM
  3. 1150 GS light bar
    By 2slowwheels in forum Oilheads
    Last Post: 01-31-2012, 10:16 PM
  4. 1150 GS Light bar
    By JOHNR100RS in forum Oilheads
    Last Post: 10-17-2010, 02:02 AM
  5. Head light for 1150 GS aDV
    By GSSteve in forum Oilheads
    Last Post: 06-21-2009, 08:45 PM
