Results 1 to 4 of 4
Thread: Vario Case Won't Expand (R1200GS)
    Registered User tmwilmotte's Avatar
    Dec 2005
    San Antonio Area (TX)
    Does anyone have experience with Vario side case that wouldn't expand? The bike is a 2011 R1200GS with only 23K miles. Hasn't been abused. I bought it used. Previous owner said he used the case (right side) occasionally, but that it's always been difficult to expand and contract. Fortunately, it stuck in the "contracted" position. When I try to flip the lever to expand it, the lever moves about 2 inches and the case expands about 1/2 inch and then gets hung up. I've sprayed some WD40 in the gear mechanisms on both sides -- doesn't help. It appears something is broken in there, or something has gotten in there to jam up the gear mechanism. I've removed the case and shaken it to try to hear anything rattling around. I've tried to expand it while the case is upside down, thinking maybe a piece of whatever might dislodge. No luck.
    Any tips on how to proceed? Has anyone repaired a side case and can offer advice? Local BMW dealer says one of the gear assemblies is about $62 and has to be shipped from Germany (of course). And then the labor would be about an hour. Not sure I want to pay about $200 for a dealer fix.
    Tom Wilmotte
    2011 R1200GS
    2009 R1200RT; 2004 R1150RT (Both Sold)
    BMWMOA, SABMWRA, IBA
    Sep 2014
    Idaho's west coast
    Had the same issue on a 2014 F800GS Vario case. I suspected it was a plastic to plastic surface hang-up caused by dust. Probed around the case all that i could with silicone spray and eventually worked it loose so that the case would expand/contract as it should. A trade for a R12GSA with the big robust aluminum cans took care of that issue. Never cared for those Vario cases that much.
    Good luck.
    CENTEX USA
    A couple of similar threads at bottom of page, most mention stuck gasket or the gears out of alignment after a fall.
    WD or silicone spray was weapon of choice.H had a set on her F650 and they required some serious tugging and silicone spray to loosen them up the first few times we tried to expand them after sitting awhile.
    Dec 2005
    Thanks, Steve & JD. I'll work on it some more. I didn't spray any WD40 between the two halves of the case where there would be friction from expanding. I'll try that. Also, BMWST forum member suggested compressed air blast in the gaps between inner and outer shell.
    Tom Wilmotte
    2011 R1200GS
  1. Replies: 2
    Last Post: 07-31-2015, 01:25 PM
  2. Need Help! Vario panniers will not expand on my 2005 r1200gs.
    By espressoforyou in forum Hexheads/Camheads
    Last Post: 09-09-2013, 02:36 PM
  3. Vario case
    By mrspeed in forum Gear
    Last Post: 08-20-2013, 06:28 PM
  4. Vario case out of alignment when extended 08 R1200GS
    By dyg in forum Hexheads/Camheads
    Last Post: 07-30-2013, 04:25 AM
