Results 1 to 15 of 22
Thread: Help resetting trip meter
    Sep 2018
    Vestavia Hills, AL
    Need help resetting the trip meter on my 2018 R 1200 GSA. I can't figure this out and my rider's manual is no help. Thank you and ride safe.
    Liaison 20774's Avatar
    Just so that people don't totally freak out, I'm going to add some context to your thread title. Might help with some searching as well.
    Mansfield,MA
    One 'splaination-
    To reset the trip menu down twice to the motorcycle picture and scroll right to "onboard computer" then menu down once then scroll down to "reset individual values" then scroll right then scroll down to "current" and scroll right once more to reset it. BMW designed it to be easy.
    On the F800GS, to remember which button it was, I painted it Hot Pink. Probably bad for the 'puter screen.
    Mod Squad
    2009 F800GS 1994 TW200
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Assuming your 2018 is like my 2017..... which tripmeter are you talking about ; there are five. All five are viewed on the Nav VI, only three are visible on the dash display. The GPS has an A and a B trip that can only be viewed and reset on the GPS. The motorcycle also has a Trip 1, Trip 2 and Trip Automatic. The automatic meter resets on its own. Trip 1 and Trip 2 can be reset using the Trip button on the left side handlebar switch cluster. Scroll thru the menu using the trip button until you get to Trip 1 or 2. Once on the appropriate tripmeter press and hold the button until it zeros. This is all covered in my owner’s manual I believe.
    To zero the Trip A and B meters on the GPS go to the Trip Data screen (you will have to search for this screen in the menu. You can put a shortcut button on your navigation screen) and depress the menu icon in the upper left corner. Then select the reset option.
    I’m doing this from memory and under the aforementioned assumption.
    Kevin Huddy
    Sep 2018
    Vestavia Hills, AL
    Thank you brother.
    Sep 2018
    Vestavia Hills, AL
    I don't have a GPS. On the top of my screen is trip 1 and trip 2. I don't have a trip button on the left handlebar switch cluster. Our bikes must be a little different.
    Registered User totgas's Avatar
    May 2018
    Brisbane / Australia
    Turn bike on (must be stationary)
    Press [Menu] button
    Keep pressing menu button until "Trip 1" is displayed
    Push selector wheel to the right (wait)
    Trip meter will zero out
    Scroll down if you want to repeat process for "Trip 2"
    Regards,
    A.
    Sep 2018
    Vestavia Hills, AL
    Quote Originally Posted by totgas View Post
    Press [Menu] button
    Regards,
    A.
    Just went out to the bike and followed your directions. Nothing! There must be some additional steps I'm missing. Here is what I tried:
    turned the bike on
    pressed the menu button to settings
    scrolled down to display
    scrolled down to trip 1
    pushed the selector wheel to the right and trip 1 turned off. I turned it back on and the same miles displayed before where there.
    Any ideas?
    Thanks for your help.
    Registered User wbrownell9's Avatar
    Jun 2013
    New Castle, DE
    Quote Originally Posted by 1hpyrider View Post
    turned the bike on
    Any ideas?
    You have to HOLD the wonderwheel to the right until it resets. Takes a few seconds, it's not instantaneous.
    2016 R1200 GSA
    Sep 2018
    Vestavia Hills, AL
    Quote Originally Posted by wbrownell9 View Post
    Thank you. Tried your directions and it still does not work. Looks like I will have to call my dealer Tuesday.
    Registered User patm's Avatar
    Mar 2016
    Montreal, QC
    Would this be what you're looking for: page 60 in the GSA Owner's manual?
    Pat
    Ride Safe!
    '16 RT
    Debbie's Servant Lee's Avatar
    May 2003
    SW Iowa
    Quote Originally Posted by patm View Post
    The OP does not have a trip button.
    Lee
    2016 R1200RS
    MOA # 30878
    May 2003
    SW Iowa
    Do you have the TFT dash?
    Lee
    2016 R1200RS
    MOA # 30878
    Sep 2018
    Vestavia Hills, AL
    No sir. The button you are showing, trip, on my bike is the menu button. My bike is an 18 GSA with the TFT screen.
    Sep 2018
    Vestavia Hills, AL
    Do you gave the TFT dash?
    Yes.
  1. '95 K75 Instrument Trip Meter
    By 72r60/7 in forum Flying Brick K-bikes
    Last Post: 01-04-2017, 08:27 PM
  2. Gut the trip meter?
    By 140008 in forum Airheads
    Last Post: 05-22-2012, 01:27 AM
  3. Trip Meter A & B 2008 R1200RT
    By chriso83 in forum Hexheads/Camheads
    Last Post: 04-23-2011, 05:15 AM
  4. RT1100 Trip Meter
    By winkwm in forum Oilheads
    Last Post: 09-19-2010, 01:51 AM
  5. 650 Trip-o-meter
    By TIGINBNA in forum Thumpers - F & G bikes
    Last Post: 03-04-2006, 02:23 PM
