Results 1 to 3 of 3
Thread: ‘57 R60 Steering Head Bearing Replacement/Upgrade
    13278
    Near Lynchburg, VA
    Pevious owner mentioned/mumbled the steering head bearings are the type that fall all over the floor (like an old bicycle) upon disassembly. Later he mentioned he had taper roller bearings in the “extra” box. Just hadn’t gotten around to it.
    Head shake at slow speed scared I the hell outta me. It has been many years since I felt that.
    Bearings may not be the total cause but changing to new may bound to be better than 60 yr old bearings.
    Barringtons “proprietary” description doesn’t tell me that what I have is correct.
    With a $10 Harbour Freight digital caliper it says the bearings are:
    ID 33.94 mm
    OD 50.96 mm
    Depth 12 mm
    Do these bearings sound correct to anyone ?
    Just trying to get prepared as best as possible.
    Any tips are appreciated with this procedure.
    Charlie
    Liaison 20774's Avatar
    Charlie -
    I did this upgrade on my R69S. From what I recall, the bearings are non-standard. I don't know how I could have measured what came out or the steering stem itself to figure out what I needed. I just bought a set from Vech. At the moment, I can't find the line in his online store that calls those out.
    13278
    Near Lynchburg, VA
    My independent mechanic confirmed that the bearings, whose measurements were in the first post, properly fit .
    I may just not pass from head shake after all. (Even though bearing replacement was more of an update, rather than service or an adjustment.)
    Charlie
  1. Steering Head Bearing Tool
    By bmwgsrider in forum Thumpers - F & G bikes
    Last Post: 04-13-2012, 03:44 AM
  2. Steering Head Bearing Clean and Lub
    By page5240 in forum Airheads
    Last Post: 05-30-2010, 03:51 PM
  3. Any Tips for steering head bearing replacement?
    By KCinSB in forum Flying Brick K-bikes
    Last Post: 06-29-2008, 03:56 PM
  4. Steering head bearing
    By ccolwell in forum Airheads
    Last Post: 04-21-2008, 11:53 AM
  5. Can't get steering head bearing capnut off
    By KHEEREMA129911 in forum Airheads
    Last Post: 09-26-2007, 09:49 PM
