Results 1 to 4 of 4
Thread: Tricks to removing the oil seal
    Hi, I'm replacing my rotor on my /5 and noted that I'm leaking a bit of oil from the seal. Is there a trick to removing (and replacing) the crank shaft seal?
    thank you Chuck
    C Routhier NY
    1972 R75/5
    1969 2002
    1982 528e
    Liaison 20774's Avatar
    Chuck -
    Brook Reams has a very nice blog on the work he did on a R75/5...here's a section that deals with removing the crankshaft seal:
    https://brook.reams.me/bmw-motorcyle...ankshaft-seal/
    I'm sure there are other ways...I was thinking that using sheet metal screws put carefully into the seal at a couple of places would let you use something like a slide hammer to pop the seal out. There are other Lisle seal pullers, some that look like a claw hammer that can be used to hook the rubber and lever the seal out.
    Hi Kurt, Brooks blog is nothing short of a masterpiece. I have seen it but hand't see that post. Thank you, will read it now.
    Chuck
    C Routhier NY
    1972 R75/5
    1969 2002
    1982 528e
    I removed the timing chest cover and did both seals that way, made it a piece of cake, but also a little more work t tear everything down and put back together
    Sent from my SM-G960U using Tapatalk
  1. Replies: 3
    Last Post: 08-10-2018, 08:07 PM
  2. Replies: 3
    Last Post: 12-22-2015, 03:05 PM
  3. Replies: 26
    Last Post: 06-09-2013, 12:38 AM
  4. Help -removing Removing a fillng adapter
    By chrismiii in forum Oilheads
    Last Post: 09-30-2009, 02:07 PM
  5. Replies: 4
    Last Post: 07-17-2008, 03:26 PM
