Welcome, Guest! We hope you enjoy the excellent technical knowledge, event information and discussions that the BMW MOA forum provides. Some forum content will be hidden from you if you remain logged out. If you want to view all content, please click the 'Log in' button above and enter your BMW MOA username and password.
Beginning April 1st, and running through April 30th, there is a new 2024 BMW MOA Election discussion area within The Club section of the forum. Within this forum area is also a sticky post that provides the ground rules for participating in the Election forum area. Also, the candidates statements are provided. Please read before joining the conversation, because the rules are very specific to maintain civility.
Hi, I'm replacing my rotor on my /5 and noted that I'm leaking a bit of oil from the seal. Is there a trick to removing (and replacing) the crank shaft seal?
thank you Chuck
I'm sure there are other ways...I was thinking that using sheet metal screws put carefully into the seal at a couple of places would let you use something like a slide hammer to pop the seal out. There are other Lisle seal pullers, some that look like a claw hammer that can be used to hook the rubber and lever the seal out.
I removed the timing chest cover and did both seals that way, made it a piece of cake, but also a little more work t tear everything down and put back together
