Results 1 to 14 of 14
Thread: 2004 R1150R - White Smoke On Startup
    Oct 2018
    North Texas, USA
    New to the bike and am curious about white smoke coming out of the exhaust for a few seconds when doing a cold start. Also noticed that I have to keep my finger on the starter button for 2-3 seconds before the engine finally kicks in. Again, that is on a cold start.
    Anything I need to check out further, or is this common? The bike has 18k miles on it.
    gig harborr ,wa
    Do you park it on the side stand? For a short time on the side this is normal on the oilheads. A load test check up would tell for a possible low battery.
    Oct 2018
    North Texas, USA
    Quote Originally Posted by EUGENE View Post
    Thanks, Eugene.
    The dealer replaced the battery when I purchased it. I do park it on the side stand, yes.
    Something else I observed: I had it out for a ride after it sat for 3-4 days and when starting up, it first misfired once and then started up. Bike always runs great once the engine is warm.
    Curious, what happens when it is parked on the side stand?
    Mansfield,MA
    It seems those bikes can have a bit of side to side oil migration when on the side stand. The similar threads panel at the bottom of this thread has some more info.
    Mod Squad
    2009 F800GS 1994 TW200
    Feb 2005
    Trinity, NC
    When you are parking the bike after a ride, shut the motor off and hold the bike up leaning it to the right side for about 10-15 seconds. Then park on the side stand. Won't eliminate the smoke on startup entirely but that should help. Oil in the chamber slips past the rings when leaned to the left and then burns off when you start it.
    As for other issue - I would do a basic tuneup. Check valves, clean big brass screws and the bypass port, sync throttle bodies, new properly gapped spark plugs. When starting, do you use the fast idle lever? It may not be working. Try holding the throttle open just a little when you next try a cold start. Take note that the Fast idle lever might be labeled "Choke", but it isn't a choke - it just holds the throttle open a little bit - if the cables are still adjusted right.
    Michael Stock, Trinity, NC
    R1100RT, R100, R60/6
    Oct 2018
    North Texas, USA
    Still getting used to using the forum and searching. Those related links are a great help! Thanks for the tip. As for the side stand, with the added explanation below, that might be all that it is.
    Awesome suggestions! Thanks for taking the time to make the list of tune-up steps! Appreciate it.
    gig harborr ,wa
    This bike does not have a choke level.
    Oct 2018
    North Texas, USA
    Not sure what that means, Eugene. Can you expound?
    Left Coast Rider
    1. Is it cool in the morning when you start the bike? If yes, you're seeing water vapour.
    2. The "choke" lever is actually a fast idle lever. Make sure you pull it all the way up when you're first starting the bike. Its in front of your left hand grip right next to the clutch master cylinder.
    gig harborr ,wa
    It is not a manual lever , it is automatic.
    Registered Schmoozer irish's Avatar
    Oct 2009
    Madison, WI
    The description of how the bike is starting sounds like normal operation to me. Same with the smoke, that happens sometimes when the bike is parked on the side stand and is nothing to worry about. Just a "feature" of the bike. Unless I am misunderstanding something I would not worry about either one.
    14 R1200GS, 02 R1150RT (retired)
    Florida & Massachusetts
    Quote Originally Posted by jbtex View Post
    The white smoke is, as others have noted, oil migration either down the valve stems or past the rings. If you ride and get the bike hot then park on the sidestand for 5 minutes, the onto the center stand for 5 minutes, what oil level do you see in the oil sight glass?
    I had a 2004RT for many years, when it is tuned properly and everything on the bike is functioning correctly it will cold start in less than 1 second every time. Mine took 2-3 seconds but with persistence I got it to less than a second. Here is the suumary: http://bmwsporttouring.com/ubbthread...789#Post940789
    Also, here is the proper cable tensioning TB adjustment procedure, which may be needed to get your fast idle lever set correctly: https://forums.bmwmoa.org/showthread...=1#post1091142
    Oct 2018
    North Texas, USA
    Very good points and input from all! Truly appreciate all of it. Makes getting to know the ins and outs of this machine that much easier.
    At this point after reading all the comments I decided that what I am observing is indeed normal for the bike/engine. I will try the trick of leaning the bike to the right after shut-off. Makes complete sense and is a suprising tip.
    Registered User tibork's Avatar
    Sep 2018
    Minneapolis MN
    Actually I also do have these on cold starts with temps in the 30s and 40s in the mornings even though I keep my bike on the center stand overnights, inside an unheated and detached garage. I do need to hold the starter for a second or two and does smoke but goes away as I am driving it. I do have manual choke and set it according to the temperatures as the manual suggests it. I too have a new battery and my bike was just tuned/serviced by pro shop. So I think this is normal unless for others same/similar bikes start up right away with no smoke.
    1994 BMW R1100RS (ABS)
  1. Still more White smoke?!
    By twisted in forum Airheads
    Last Post: 10-20-2016, 02:40 PM
  2. RT pumping white smoke on startup
    By derost in forum Oilheads
    Last Post: 05-23-2013, 01:05 PM
  3. 2003 K1200 Smoke Cloud on Startup
    By hans.arnesen in forum Flying Brick K-bikes
    Last Post: 07-02-2012, 08:23 PM
  4. Blue smoke on startup.
    By bobgerman in forum Oilheads
    Last Post: 06-15-2011, 09:29 PM
  5. White Smoke ?????
    By SGTBORING in forum Oilheads
    Last Post: 11-06-2006, 07:22 PM
