Results 1 to 14 of 14
Thread: Cost effective bore scope
    Liaison 20774's Avatar
    A friend showed me this today. Depstech WiFi Endoscope. I don't like the name endoscope but it function very well. LED lights on the end to illuminate what you want to see. Use a smartphone to connect to the scope through WiFi. I found it to be really clear and could get quite close to the subject material. Has a couple of attachments for the end. I can see how it might be useful for cylinder inspection through a spark plug hole.
    http://www.depstech.com/?portfolio=d...wifi-borescope
    Mansfield,MA
    I would have to see how this works in person. I have one of the common styles, mine is a Bosch-
    https://www.boschdiagnostics.com/diy...spection-scope
    For “raw” viewing it’s ok.......for close up, fine work.....Meh.
    It has a fixed focal length so as you work it towards the objective, the objective only looks good from a set distance. This seems to be common with this type of bore scope.
    If, by using a WiFi device, they have figured a way around this- it would be a winner.
    My favorite ($$$) is by Gradient Lens-
    http://www.gradientlens.com/FlexibleBorescopes.aspx
    Mod Squad
    2009 F800GS 1994 TW200
    I was pretty impressed with what I could see. I stuck it in a drawer and closed the drawer...could really see well.
    The WiFi is really just used to bring the image from the device to a viewer, in this case your smartphone.
    The MOST cost effective sighting is 3 rds out of the gun to have it sighted in. It only takes 3 rds to sight any long gun in. Anyone here savvy enough to know how to use just 3 rounds and have the rifle sighted in?
    I'll explain how in a subsequent post. Back in 94 I was shown this at HK at their leo counter sniper week long course of fire/training. 3 rds is all it takes, I've had to show this way to two teams of USAF PJ's using their m4's with aim points.
    3 rds at the most will cost you 6.00. Don't get much less expensive than that folks. And I don't need a phone, wifi etc. By the time one sets this up, a rifle shooter with the knowledge of sight in in 3 rds will have dialed in the gun, fired what he wanted to check zero and be gone from the range.
    The lion does not even bother to turn his head when he hears the small dog barking.
    https://www.youtube.com/user/azqkr
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Quote Originally Posted by brownie0486 View Post
    I think you may be unclear about the topic being discussed.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Mansfield,MA
    Different kind of bore
    On a rifle, remove bolt and look through barrel align scope and test.
    On a spark plug hole, looking for a dropped electrode, use one of the above methods/tools.
    Mod Squad
    akbeemer, yes, I was thinking different bore.
    OM, if it's not a bolt gun, what then?
    Jul 2007
    That’s understandable. I thought it was a discussion about a colonoscopy.
    Kevin Huddy
    I use one like this:
    https://www.ebay.com/itm/USB-Endosco...IAAOSwfEVazbQY
    About $12 on ebay.
    Works but does not fit smaller spark plug holes.
    -I just wanna ride on my motor sickle-
    I have a similar device. The probe is not 6 feet long on mine, and the darn end won't go through a spark plug hole. And I paid a lot more for it. I believe this one in the OP's post is actually a medical device.
    Quote Originally Posted by akbeemer View Post
    Mansfield,MA
    It is an “over 50” kind of group
    om
    Mod Squad
    AZ
    A colonoscopy device is much larger in diameter than the scope linked in this thread. That is why they put you out before they bring it out!
    MOA #107139
    RA #28511
  1. Replies: 9
    Last Post: 05-04-2015, 10:10 PM
  2. Siebenrock Big Bore Kit
    By tonyo in forum Airheads
    Last Post: 11-06-2013, 10:26 PM
  3. How effective is ATGATT?
    By PAULBACH in forum Gear
    Last Post: 12-13-2008, 06:46 PM
  4. Most Effective Horn Sequence?
    By dinandan in forum Campfire
    Last Post: 07-31-2008, 06:48 PM
